Following is a power supply with dual +-15V output:
http://docs-europe.electrocomponents.com/webdocs/13f8/0900766b813f8a87.pdf
I'm confused to understand two points:
1-) What is the difference between Output A and Output C ? Both looks variable. One is 1A the other is 0.2 A. I cannot figure out what is the difference. For dual op-Amps which one should be used?
2-) It also says 0 to 30V. How can it be configured for that? Output A with +15 plus and -15 GND?
  • \$\begingroup\$ Some of the statements on that brochure don't make sense to me. I'd want to look at a proper user manual or schematic diagram to determine what voltages are really available under what circumstances. \$\endgroup\$ Jun 6, 2016 at 20:12
OUTPUT A is a pair of tracking outputs. Press the OUTPUT SELECTION button and the OUTPUT A LED will probably blink (I didn't check). Pressing the up/down keys will cause both to be adjusted. e.g., ±15, ±14, ±13, etc., or in 0.1 V steps. Use these for dual rail opamps.
OUTPUT C is a second single supply adjustable independently between -15 and +15 V. This could be useful, for example, to apply a DC voltage into your opamp circuit.
You're right - it can't. It's 30 V between the blue and the red socket but that will only be useful if you don't need the COM reference. It will be symmetrical around the COM terminal.
Wow!
  • \$\begingroup\$ I want to buy a cheap power supply with variable outputs and +-15V split supply option. This is the only one I could find in RS. Would you recommend it for hobby projects? \$\endgroup\$
    – user16307
    Jun 6, 2016 at 20:15
  • \$\begingroup\$ It depends on your requirements. You've already identified one limitation. I would be inclined to get a single adjustable supply and a fixed ±12 or ±15 V supply for the opamps. You generally don't need much current for these but the big adjustable can be used to charge batteries, etc. \$\endgroup\$
    – Transistor
    Jun 6, 2016 at 20:18
  • \$\begingroup\$ I don't want to have two supplies and I dont want to waste time for creating split supplies each time. The two output ones are easy to make split but they are expensive. What could limit me if I use this one? \$\endgroup\$
    – user16307
    Jun 6, 2016 at 20:21
  • \$\begingroup\$ This doesnt have current limiting. Is that a big problem? \$\endgroup\$
    – user16307
    Jun 6, 2016 at 20:23
  • \$\begingroup\$ The lack of current limiting is a problem. It's a very useful feature when powering up a circuit, device or motor that may have a fault. It reduces the possibility of damage. The other problem is the lack of flexibility because the COMs are all internally connected. \$\endgroup\$
    – Transistor
    Jun 6, 2016 at 20:25
output A: you can select any two voltages (blue, red) in the range of -15V to +15V, that is 0v to -15v is obtained from the blue colored terminal , 0v to +15v is obtained from the red colored terminal.
output C: it is a single output terminal through which we can obtain only one voltage in -15v to +15v interval
for op-amps we use output A.
if -15v is considered as the reference voltage, output A behaves as 0 to 30v variable power supply.
  • \$\begingroup\$ When would you use Output C? Lets say you need +9V, Which output would you choose? Why? \$\endgroup\$
    – user16307
    Jun 6, 2016 at 20:26
  • \$\begingroup\$ It depends on the current. We usually choose low currents and so using output C is better. \$\endgroup\$
    – user113205
    Jun 6, 2016 at 20:53
