6
When there are a lot of connections and nets, these rats nest of nets can be a bit troublesome during layout. Does anybody know how to remove/hide the rats nests?
6
You can do this by going to your layer set properties (click the colored box at the bottom left of your screen):
On the right-hand side uncheck the box labeled "Show" next to "Default color for new nets":
This will hide all airwires at once.
  • \$\begingroup\$ I have to mention that it works but the rats nets will come back if going from 2d to 3 \$\endgroup\$
    – chris
    Commented Jun 7, 2016 at 6:50
7
In Altium Designer 16.x, while viewing the PCB go to View > Connections > Hide All.
This will hide all of the ratnest nets. If you select a component that one component's nets will be shown as a convenience, but other than that I think this solves your problem. I find it useful to enable this option during initial placement of a crowded design.
Right click on a net, and choose Net Actions >> Hide Nets.
  • \$\begingroup\$ I want to remove them all , not one by one. \$\endgroup\$
    – chris
    Commented Jun 6, 2016 at 20:21
