Datasheet link I am unsing full duplex RS485 feature IC.
Please confirm below
To use this IC in half duplex mode I need to short Pin B to pin z and Pin A to Pin Y. Since thease pins are internally not shorted ( beacuse it is full duplex feature IC). enter image description here
    \$\begingroup\$ Yeah just connect them. Basically treat this IC as if it was 2 separate MAX485 transceivers. \$\endgroup\$
    – Lundin
    Commented Jun 8, 2016 at 9:00
    \$\begingroup\$ Perhaps looking at datasheet sometimes, can answer lot of questions. \$\endgroup\$ Commented Jun 8, 2016 at 10:08
  • \$\begingroup\$ Don't forget that you can combine nRE and DE to one net in half duplex. \$\endgroup\$
    Commented Jun 8, 2016 at 10:50
You are correct -- Y to A and Z to B is what you need to do for a half duplex app -- you can also connect DE to /RE on the other side.
