LDI R16, 0x25 --> E 2 0 5 --> 1110 0010 0000 0101
Apparently, in AVR, the code and data are stored separately and each area (code, data area) is accessed by a unique bus.
Now since the Program Counter contains the address to the next
instruction which in this case is LDI: PC --> E (PC points to 'E')
My question is, when loading the data parts (instruction) within 1 clock cycle, well.. opcode 'E' is directly referred to by the PC. How does the CPU find the data portion (0010 0000 0101)?
Or have I got it entirely wrong and are the 2 bytes (E + 0010 0000 0101) of the instruction the 'code' and kept as a single unit in the code area. In which case what is the data area - is that for instructions that use memory addresses: eg,
LDS R10, $FFFF Here code is the bytes for the entire instruction and the data is probably populated by the assembler from some variable assignment?
Why then does he say:
In Sections 2-2 and 2-3, you learned about data memory space and how to use the STS and LDS instructions. ?Then the CPU wants to execute the ?LDS Rn,k? instruction, it puts k on the address bus of the Data Bus, and receives data through the data bus. For example, to execute ?LDS R20, 0x90?, the CPU puts 0x90 on the address bus. The location $90 is in the SRAM (see Figure 2-4). Thus, the SRAM puts the contents of location $90 on the data bus. The CPU gets the contents of location $90 through the data bus and puts it in R20.
WTH? Could someone clearly explain AVR code/data bus architecture and how instructions are fetched and executed?
