I'm using an LT1339 switching regulator to create a 24V to 12V 50A power supply and after using the calculation in the datasheet for the LT1339 I think that I need a 60uH Inductor but a 60uH, 50A inductor doesn't exist.
Lmin = (Vout)(Vin-Vout)/(Δl)(freq)(Vin)
((12)(24-12))/((1)(100000)(24))=Lmin
144/2400000=0.00006H = 60μH
What can I do here and is my calculation even correct? The datasheet is here and my schematic is below.
Also, please feel free to critique the schematic/component values/my life choices/etc.
  • \$\begingroup\$ What is the minimum output current you need? (If it is reasonably high, the inductor can be smaller). \$\endgroup\$ – Peter Smith Jun 10 '16 at 11:40
  • \$\begingroup\$ Minimum would be 24A \$\endgroup\$ – dotDone Jun 10 '16 at 12:30
  • \$\begingroup\$ Why do you have those four 2200uF capacitors in series? \$\endgroup\$ – Michael Karas Jun 10 '16 at 12:43
How about rolling your own inductor?
All you need is the peak instantaneous current passing through the inductor. Next, pick a big ferrite kit (possibly planar E64). Look at the data sheets and choose the most appropriate material (to suit frequency of switching). Then see how many turns are required.
From the turns and peak amps you can calculate H (magnetic field strength) - it's basically amps x turns divided by effective length of the core (specified in the data sheet). Next you look up B (flux density) from the BH curve of the material used.
Then you decide (from the BH curve) if the core is starting to saturate too much. If it is then you need a gap between the core halves. This reduces core effective permeability so you then need more turns to get back to the same inductance BUT, if you drop permeability by say 4 times you only need twice the number of turns to restore inductance (L is proportional to turns squared). The net effect is that permeability has quartered, H has gone up by 2 and B is reduced by 2 hence much less saturation.
Will it work?
Power to load is 600 watts (12V at 50A) and, at a switching frequency of 100 kHz this means a deliverance of 6 mJ of energy per cycle of switching. Peak current could be about 51 A because the energy liberated from an inductor as it loses 2A from 51A to 49A is: -
\$\dfrac{(51^2 - 49^2)\times 60 \mu}{2}\$ = 6 mJ (this is at full load i.e. average current = 50A).
An E64 core of 3C90 material has an inductance factor (AL) of 14640. This means two turns yields an inductance of ~ 60uH.
H is therefore \$\dfrac{2\space turns \times 51\space amps}{core\space length (80mm)}\$ = 1275 amps per metre,
However, this will be significantly saturating 3C90: -
So, a gap is needed and that gap is needed to reduce the permeability (and AL) by at least 5. The basic ratio between B and H is the magnetic permeability hence if this is reduced by 5 then H can increase by 5 for the same level of saturation in the core material.
The tables in the specification sheet for the E64 core tells you that with a gap of about 0.66 mm, AL drops to 1000 and to re-establish the inductance to 60 uH, eight turns are needed (~ 64 uH). This is an AL/permeability reduction of about 15 so it's possibly an overkill. H now must increase 4 times (due to the turns increasing by 4) but, because permeability has dropped by 15 the net reduction in the saturation point is by a factor of about 3.75. It's still a little close but hopefully you get the general idea.
So an E64 made from 3C90 material with big fat PCB tracks of 8 turns is possibly what you can get away with. Adding a gap provides a way to trade between copper losses and core losses.
| improve this answer | |
  • \$\begingroup\$ Thanks so much for your detailed feedback, I feel that I am much better prepared to approach the situation now. I have taken your advice and looked at the E58/11/38-3C90 cores but how did you calculate the number of turns required? I have identified the AL as 8480 w/ 0 air gap but the only calculation for number of turns I know gives me 0.00307 (N=sqr (L10^3/AL)) \$\endgroup\$ – dotDone Jun 10 '16 at 16:26
  • \$\begingroup\$ The 8480 number is 8.48 uH per turn and given that two turns produces 4 times the inductance you just divide 60 by 8.48 to get 7.08 then take the sq root to give #turns then round up or down hence sqrt of 7.08 is 2.66 so rounding up gives three turns and this gives an inductance of 76 uH (a bit high). But you will need to gap this device so it's going to need more like 8-10 turns off the top of my head. \$\endgroup\$ – Andy aka Jun 10 '16 at 16:34
