I am planning to switch the 5V line to a USB load.
I have being going around different suppliers looking for an optocoupler that can handle 3A at 5V. I have seen a few, but upon looking at the datasheet (e.g., FOD3182), they mentioned that the operating voltage should be at 15 to 30V.
If there aren't any such optocouplers, how can I solve my problem?
  • \$\begingroup\$ Please see the Help Center for rules about shopping questions. Your question will be closed if it remains in its current form. You need to change it to a design question. You also omitted to link to the device datasheet. \$\endgroup\$
    – Transistor
    Jun 11, 2016 at 8:21
If there aren't any such optocouplers, just build your own:
optocoupler switches MOSFET
The actual optocoupler needs to pass very little current because it controls only the gate of the MOSFET.
Choose a logic-level MOSFET that switches on completely at VGS=−5V, and has a low enough RDS(on) for your application.
In this circuit, the optocoupler activates the switch. To invert the logic, exchange IC1 and R1.
An optocoupler than can handle that load exists, but it has a different name: "solid-state-relay"
You can use 4n35 with N mos as in this diagram: http://www.alcs.ch/webdata/arduino/dimmer/dimmer_v1.png
What will be the load ? Because you may need extra diode for motor load for exemple
