I have a design in Quartus that includes an (on chip) RAM module that was created using the altera mega wizard. The wizard warns me that to simulate i need to include the altera_mf file.
When I load my design in Modelsim and try to simulate, it errors out with "cannot instantiate altsyncram. Module not found.
Below my work library is a library called altera_mf which includes the altsyncram module in there. However, I cannot seem to figure out how to make Modelsim use it.
How do I add/link the altera_mf library to my project?
You need to link to the library.
Assuming it is mapped (i.e. you see altera_mf as a library as you say), this is just a case of adding a switch to your vsim command:
vsim  <options> -L altera_mf  <toplevel>
Replacing <options> with any existing options you have, and <toplevel> is the name of the top level module (which you should already have in your command).
If that doesn't work, you will also need to make sure the library is mapped:
vmap altera_mf ./path/to/your/libraries/altera_mf
  • \$\begingroup\$ thx that worked. \$\endgroup\$ – ErwinM Jun 12 '16 at 17:48
