It is known that the initial feedback signal is developed from the noise in the resitors and the transients of the power supply. The question here is : why the waveform at the output is sine wave particulary and not any other waveform?
closed as unclear what you're asking by Dmitry Grigoryev, Bence Kaulics, PeterJ, Daniel Grillo, uint128_t Jun 14 '16 at 16:08
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Because that's the solution of the equation describing the oscillator. Is there something specific you wanted to know about it? \$\endgroup\$ – Dmitry Grigoryev Jun 14 '16 at 7:50
Barkhausens oscillation condition is applicable for LINEAR systems (with feedback) only. This condition requires a loop gain of unity (magnitude of "1" and zero phase). For most of the frequency-dependent networks this phase condition can be fulfilled for one single frequency only. Hence, there is only one single frequency, which can lead to self-sustained oscillations. In case of the WIEN oscillator a simple RC bandpass is used providing a magnitude maximum and a phase of zero deg at the same frequency.
As mentioned, this applies to linear systems only. On the other hand, a safe start of oscillations needs a loop gain slighter larger than unity - with continuously rising amplitudes. In order to make sure that the amplitudes are not hard-limited (clipped) at the supply voltage rail, we use an amplitude-control mechanism to enable soft-limiting which can maintain the sinusoidal form of the signal.
