I have seen this question and removed the "#.." part of my code to introduce delay, since my code will ultimately run on hardware.
Anyway, I am trying with counters and not able to introduce the required delay of n clock cycles. Here is my code:
`timescale 1ns / 1ps
module SyncDelay( clk_27,vsync,vsync_o);
 input clk_27;
 input wire vsync;
 output reg vsync_o;
 reg[2:0] cnt=0;
 always @ (clk_27)
 begin
    if(cnt > 3'd4)
    begin
        vsync_o = vsync;
    end
    else
    begin
        cnt = cnt + 1;
    end
 end //always
endmodule
This is what I'm getting:
vsync and vsync_o have the same values at all instances. Instead, I want vsync_o to lag with a delay of n clock cycles.
EDIT:
With the code:
   input clk_27;
   input wire vsync;
   output reg vsync_o;
   reg[2:0] cnt = 0;
   always @ (clk_27)
   begin
      if(cnt > 3'd4)
      begin
          vsync_o = vsync;
          cnt = 0;
      end
      else
      begin
          cnt = cnt + 1;
      end
   end //always
  endmodule
I get:
    \$\begingroup\$ Upvoted even though I have no idea what you want, but you seem to have done the preliminary groundwork before asking. :) \$\endgroup\$
    – pipe
    Commented Jun 15, 2016 at 12:39
  • \$\begingroup\$ Thanks! I want the values appearing on vsync signal to appear on vsync_o signal after n clock cycles. I hope I am clear now. \$\endgroup\$
    – Saania
    Commented Jun 15, 2016 at 12:47
That is not a correct way to add a delay. This technique will lead to missed pulses, or wrong pulse length. Bascially, here, you're just synchronizing your output every 4 cycles.
To make a proper delay, you need n flip-flops, n being the number of delay cycles you want to introduce. Make it an array: reg[3:0] bits;. Now, at each clock cycle (posedge / negedge, as you want), set the output to the value of the the last bit: vsync_o <= bits[3]; and shift the whole array, inserting the current input value: bits <= {bits[2:0], vsync};.
You don't need (and don't want) a counter. What you need to remember is the state for each clock cycle you're delaying. This is basically simply a shift register.
Edit: Okay, I was hoping it wasn't necessary, but here is the full code for a 5 cycles delay (did not try to compile it, though):
input clk_27;
input wire vsync;
output reg vsync_o;
reg[3:0] bits;
always @ (posedge clk_27)
begin
    vsync_o <= bits[3];
end //always
endmodule
  • \$\begingroup\$ Could you help me with the coding part? I know I have to use a D flip-flop. \$\endgroup\$
    – Saania
    Commented Jun 15, 2016 at 13:17
    \$\begingroup\$ @Meghana Not a D flip-flop. You want several of them. One for each delayed cycle. Anyway, I made the edit. \$\endgroup\$
    – dim
    Commented Jun 15, 2016 at 13:25
cnt is never reset to 0.
I would add a statement resetting it right after vsync_o is assigned (inside the begin/end group)
  • \$\begingroup\$ Did it work? If not, you may need to do something more complicated in the reset (based on change in vsync_o instead of clk27) \$\endgroup\$
    – MikeP
    Commented Jun 15, 2016 at 12:55
  • \$\begingroup\$ Yeah, you're right, it seems to look better. Thanks! But the pulse width of vsync_o and vsync do not match (shown in the edited question above). What's the reason? Please note that I want the exact same information to appear on vsync_o as that of vsync, but after a particular amount of clock cycles. \$\endgroup\$
    – Saania
    Commented Jun 15, 2016 at 13:14
  • \$\begingroup\$ that a correct observation, there should be a condition to reset the counter \$\endgroup\$ Commented Oct 4, 2019 at 17:31
