I would like to use 555 with a relay to make a reliable control circuit.
I use 555 as mono-stable and the following equation does not work:
t = 1.1*R*C seconds
R = 51 K ohm
C= 220 uF
The output should be high (1) for about 12 sec but it does not. It is high for 6 or 7 sec only!! then it goes to low (0).
  1. What causes this error? Is the previous equation ideal and I should use practical one?
  2. I noticed that the 7 sec are constant. They don't change. Will they be constant for ever? If yes, I will increase the resistance to get 12 sec then I will continue building my project.
  3. If 555 is not reliable, Would you suggest me any other IC to control time?
Thank you,
    \$\begingroup\$ The 555 is not meant for any accurate timing. Additionally to its internal manufacturing tolerance to the 1/3 level, your resistor will be off (probably up to 5%) and the cap will be off too (probably up to 20%) plus nobody knows how you connected things, and that this formula complies to your layout. \$\endgroup\$ – PlasmaHH Jun 15 '16 at 13:55
    \$\begingroup\$ If you are seeing acceptable stability in the error but need better accuracy, then by all means substitute a 100K 10 turn trim pot. Depending on the consistency you need, however, you may have future disappointments, due to the effect of temperature changes on all the components. \$\endgroup\$ – Randy Jun 15 '16 at 14:15
That 220 uF capacitor will be an electolytic one, they're well known to have inaccurate values. The value will also be slightly voltage dependent and since the capacitor is charged and discharged in your circuit, you end up with a highly unpredictable value.
I see the following options:
  1. Try with a different value capacitor until you get the right timing value. You could also use several capacitors in parallel (like 100 uF and a 22 uF) if you need.
  2. Use a 7555 or TLC555 this is the CMOS version of the 555, it can work with very high value resistors, like 1 M ohm. Then you could use a more accurate ceramic capacitor.
  3. Forget about the 555 and use HEF4060 oscillator + counter IC, it needs a resistor and a small value capacitor to run an oscillator but it also provides frequency divided versions of that signal so you can still make long timing values.
  4. Forget about the 555 and use a microcontroller. If that MCU is used with an external timing crystal or resonator you can achieve timing accuracy almost as good as your digital watch. No that's not expensive, I have Arduino nano modules with a crystal and they're 2 Euros a piece.
| improve this answer | |
    \$\begingroup\$ And if 2 euros are too expensive, a tiny PIC will be cheaper and the factory-calibrated on-chip oscillator probably good enough. \$\endgroup\$ – pipe Jun 15 '16 at 15:00
  • \$\begingroup\$ I am trying to use 10 MegaOhm resistor with 20K in 555 timer and that might be the case why blue capacitor (ELECTROLYTIC 47 uF) or 555 timer not working and it is making me mad from many days as per part of your answer - \$\endgroup\$ – Moons Jan 2 at 17:41
Put the thing in a freezer and I expect the 7 seconds will change. Capacitor values are not precise and float around all over the place depending on conditions.
If you want accurate timing you'll need to drive it from a crystal. There are various howtos for doing this with 4060B CMOS counters (add more counters to extend the time). But in practice a small microcontroller is more flexible, easier to adjust, and may take less power and board area.
