I already know that charging or discharging a battery causes it to heat up, and that increase in heat is proportional to the current. But what physical process is behind this?
My back-of-the-envelope explanation would be that the battery has internal resistance, and the current must overcome this resistance. In doing so, the electrical energy is converted into heat. In other words, the electrons crash into poorly-conductive parts of the electrodes, heating the material up.
But is it really as simple as that?
  • \$\begingroup\$ The internal resistance is likely to be in the electrolyte, i.e. in the chemical reactions, but essentially, yes. \$\endgroup\$
    – user16324
    Commented Jun 15, 2016 at 15:07
    \$\begingroup\$ Yes.‏‎‏‎‏‎‏‎‏‎‏‎ \$\endgroup\$ Commented Jun 15, 2016 at 15:07
  • \$\begingroup\$ @BrianDrummond I thought the resistance is at the interface between the electrode and the electrolyte and is caused in part by material deposition from irreversible reactions. \$\endgroup\$ Commented Jun 15, 2016 at 15:19
    \$\begingroup\$ Some of the heat is related to the chemical reactions, but a lot of it is simply due to the fact that the bulk materials impede the flow of electrons and ions. \$\endgroup\$
    – Dave Tweed
    Commented Jun 15, 2016 at 15:27
    \$\begingroup\$ @StephenBosch you may be right, or limited ion mobility to that interface may also appear as part of the resistance, I'm not sure. But I don't think it's the deposition of insulating material (that would surely kill a cell fast!), but decreasing concentration of active reagents in the electrolyte, limiting reaction rate. \$\endgroup\$
    – user16324
    Commented Jun 15, 2016 at 15:28
There is resistance in the metal of the plates and wiring, active plate materials, and electrolyte. The heat produced by this resistance is proportional to current squared.
In metals the resistance is caused by electrons 'crashing into' atoms as they move through the conductor, but in electrolytes entire molecules are moving. Electrolyte conductivity is strongly affected by ion concentration, so its resistance will increase as the battery is discharged and fewer ions are left in solution (those fewer ions must move faster to create the same current, and thus have more collisions which is seen as higher resistance).
Also the chemical reactions involved may be endothermic or exothermic. This occurs because the different bonds between atoms before and after the reaction may require more or less energy.
In a NiCad battery the charging reaction is endothermic, but the discharge reaction is exothermic. So when charging it actually sucks heat from its surroundings and stays cool (until it is full and the reaction finishes), while during discharge it produces heat and gets hotter than you might expect. NiMH batteries do the opposite - they get hot while charging, but cool themselves during discharge.
The other factor that must be taken into account is temperature. A 10°C increase can double the activity of ions in an electrolyte, which will cause its resistance to drop dramatically. As the battery warms up the heat produced by electrolyte resistance will reduce, slowing the internal temperature rise. However the reduced voltage drop also results in higher terminal voltage, so the load may more draw current (or the same, or less, depending on what type of circuit the battery is powering).
With all these factors having an effect, accurately calculating the rise in battery temperature during operation is not easy. You can get a resistance measurement by simply applying a step current and measuring the instantaneous voltage drop, but this value will vary depending on temperature, state of charge and current.
  • \$\begingroup\$ This is the kind of answer I was looking for. \$\endgroup\$ Commented Jun 16, 2016 at 11:49
