There is a simple design for an H-bridge that I keep seeing all over the place.
My Schematic
This design is featured on the Sparkfun tutorials website as well as other places (just google image search pnp h bridge). There's a similar design I found that is even more common, and was even discussed on this SE site where it's been referred to as a "textbook example". It's a little different, but still has the same problem, just not as severe.
Textbook Example
In the first example per se (leaving the two data inputs out of it), is this not a short circuit? Positive current from VCC would flow right into Q1 and out Q3, partly activating both transistors (to an equilibrium state), and the exact same thing happens on the other side with Q2 and Q4.
I would expect the same to happen in the latter example, however for current coming from VCC to activate both transistors on either the left or right-hand sides, current would need to flow through 2 kOhms. When I ran this exact example in a simulator with a 12 V VCC (without the additional signalling electronics plugged in), I observed a fluctuating ~0.5 A current through each transistor.
Now I understand that the signalling electronics change things a bit. Since the second example here has those resistors, as long as the 4093s are sinking current, the bottom transistor won't activate. However when the 4093s are sending a high voltage signal, it better be at least equal to VCC/2 or there'd be a voltage drop over the top transistor on that side and both would activate. This is going to briefly be the case during switching. Now imagine using this with a PWM signal.
The first example is even worse. In order to prevent the PNPs from activating the signal would need to exert an un-resisted high voltage, basically shorting out your microcontroller or other electronics. And before someone answers that the first example is just "conceptual", take a look at the other circuits exemplified on the same Sparkfun page - lots of resistors and short circuit protection.
I tested these in a simulator which seemed to confirm my intuition. Is there something I'm not seeing? Do these designs somehow function differently in reality than expected for some reason? Why are these designs so popular and why would anyone consider them safe?
  • \$\begingroup\$ The idea of an H-bridge is diagonal conduction. When Q1 and Q4 are on, Q2 and Q3 must be off. Conversely when Q2 and Q3 are on, Q1 and Q4 must be off. Why do you think Q1 and Q3 would be on at the same time? They are driven by the same signal, after all, and they're opposite in construction (PNP vs NPN) ... if the driver is 'high' (=Vcc) the PNP VEB = 0 and the NPN VBE is forward biased. \$\endgroup\$ Jun 16, 2016 at 20:50
    \$\begingroup\$ ... Except for "shoot-through" when the inputs are in transition and not fully high or low. \$\endgroup\$
    – Tut
    Jun 16, 2016 at 20:57
  • \$\begingroup\$ Simple mind design simple (or maybe stupid) circuit. \$\endgroup\$
    Jun 16, 2016 at 21:17
Perhaps the author chose to ignore the fact your first circuit will not work with supply voltages exceeding about 1.2V or perhaps he or she did not understand. Who knows? There is no shortage of bad circuits on the internet. When the supply voltage exceeds two Vbe drops, both base-emitter junctions conduct and the transistors will be destroyed if enough voltage is applied.
The second one will actually work, but will tend to have brief shoot-through on switching because the transistors will not switch off instantly, so both will likely briefly be on during switching.
    \$\begingroup\$ P.W.M. = R.I.P. \$\endgroup\$
    – JSideris
    Jun 16, 2016 at 21:06
  • \$\begingroup\$ @JSideris Succintly put. \$\endgroup\$ Jun 16, 2016 at 21:07
    \$\begingroup\$ @SpehroPefhany The author in this case is OP who conveniently left out the warning from SparkFun: Note: there’s usually quite a bit more to a well-designed H-bridge including flyback diodes, base resistors and Schmidt triggers. \$\endgroup\$
    – pipe
    \$\begingroup\$ @pipe In other words, conceptual only. Sounds about right, although I don't think I would have left "usually" in there in this particular case. No need for weasel words. \$\endgroup\$ Jun 16, 2016 at 21:19
  • \$\begingroup\$ @pipe Not at all. I conveniently provided a link so that we can discuss that. Both the wording and the context on that page make it seem as though base resistors are optional, like the flyback diodes and schmidt triggers. After all, base resistors are included in all the other circuits on that page, it would seem that including them would be prudent as the provided circuit hardly qualifies as an H-bridge without them. \$\endgroup\$
    – JSideris
    Jun 16, 2016 at 21:42
The key is that this is a tutorial circuit aimed at a specific aspect of h bridge design.
There is no suggestion in the tutorial that this would usually be suitable for real world use. It would more-or-less work as is in very limited special cases , which is essentially what the tutorial says. In the tutorial it is used to demonstrate the basic switching principles and components which are not related to the basic action are not shown so that 'the student' may concentrate on the point being demonstrated.
Letting this circuit escape into the real world would usually be a bad mistake.
Note that if MOSFETs are used instead of bipolar transistors then the circuit will work 'after-a-fashion' in far more cases.
