I've seen both of these in the PCB tab when editing the PCB board in Altium Designer.. what are the two?
I thought I new, but I have fully routed traces with signal lengths of 0 as well as signal and trace lengths that are totally different from each other. As well as sometimes signal lengths go up and down with the trace lengths as I'm routing, but other times the signal lengths do not change...
What are these two things, how are they related, and how do I edit signal lengths? (I'm assuming I'm right in thinking trace lengths are determined by the physically routed length of the traces. If not then please explain).
Thanks!
If you have access to Altium's forum please look at these two threads: https://forum.live.altium.com/#posts/215294 https://forum.live.altium.com/#posts/215784
If you have no access, the basics are:
Routed length - sum of all segments of a net. Having overlapping segments will give falsely larger numbers.
Signal length - calculated as length of path along a net between two pads. Signal length = 0 means there are either 1 or 3+ pads in the net. Altium can only calculate signal length for a 2-pad net.
  • 4
    \$\begingroup\$ I'm trying to figure out what possible asinine reason Altium could have to prevent anonymous people from reading their help forums. I can't think of anything. \$\endgroup\$ – Connor Wolf Dec 3 '16 at 10:01
