I'm trying to write a loop for two binary values that repeat periodically at a specific amount of time that goes indefinitely or until a certain condition is met.
Here is what I have wrote (below), but the error states that I should be using the 'wait' statement with 'until' but when I use that then it says that the Boolean expression is used incorrectly.
This leads me to believe I'm using the loop wrong or doing something else wrong that I can't figure out.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity moove is
    port (clk : in std_logic;
        rst : in std_logic;
        count : out unsigned (7 downto 0));
end entity;
architecture moving of moove is
    constant period : time := 19.5 ms;
    constant cycles : integer := 120000;
begin
    forwrd: process (clk)
    begin
        if rising_edge(clk) then
            if rst = '1' then
                count <= "00000000";
            elsif rst = '0' then
                for i in 1 to cycles loop
                    count <= "01100100";
                    wait for period;
                    count <= "10010110";
                    wait for period;
                end loop;
            end if;
        end if;
    end process;
end architecture;
    \$\begingroup\$ Are you trying to simulate this code or synthesize it? wait for ... statements are not synthesizable. \$\endgroup\$ – Dave Tweed Jun 21 '16 at 11:11
  • \$\begingroup\$ First, simulate and then synthesize \$\endgroup\$ – Serge Jun 21 '16 at 11:17
  • \$\begingroup\$ Would you have any suggestions to a better approach? \$\endgroup\$ – Serge Jun 21 '16 at 11:19
  • \$\begingroup\$ If you will synthesize it you need to use a separate timer for the period of the signal instead of wait \$\endgroup\$ – Claudio Avi Chami Jun 21 '16 at 11:30
    \$\begingroup\$ Do you mean a counter, that will count to a specific value (time) and then i would load my binary value to the signal? \$\endgroup\$ – Serge Jun 21 '16 at 11:37
Here is the working version. I'm using 100kHz clock.
library ieee;
use ieee.std_logic_unsigned.all;
entity moove is
        rst : in std_logic;
end entity;
    signal Cnt: std_logic_vector(11 downto 0);
begin
    begin
    if Rst = '1' then
        Cnt <= (others => '0');
            elsif (rising_edge(Clk))then
            Cnt <= Cnt +1;
            if (Cnt = "011111010000") then--20ms(2000 clock cycles)
            count <= "10010110";--1.5ms
            elsif (Cnt = "111110100001") then
            Cnt <= "000000000000";
            count <= "01100100";--1ms
end if;
end if;
end process;
end architecture;
| improve this answer | |
