This lecture (page 10) gave derivation of common source output resistance.
What I don't quite get here is why we should set the input source equal 0 for calculating output resistance. Why?
7 Answers 7
My answer is written as if dealing with a real circuit amplifier but the same principle is involved when calculating values.
You don't have to set the input source to zero if you want to do it the harder way.
That harder way would test the impedance at a specific frequency other than what the input source is producing then you would use a tight band-pass filter (or fourier/spectral analysis) to analyse JUST the signal at the frequency you want to measure and calculate output impedance.
Yes, you can do it that hard way or, just set the source voltage to zero and do it the easy way. Alternatively you can use the input signal to generate a voltage and then place a load at the drain/collector and when that AC voltage seen drops to 50% you have the equivalent of the output impedance.
  • \$\begingroup\$ Thank you. Is there a way to formally prove that the two methods above are equivalent? \$\endgroup\$
    – emnha
    Jun 25, 2016 at 5:48
    \$\begingroup\$ It's the principle of superposition that springs to mind. In fact it's the reverse of this - signals that can add together can be fully removed from each other providing that the spectrum of each doesn't overlap. \$\endgroup\$
    Jun 25, 2016 at 10:02
  • \$\begingroup\$ yes, I also thought about superposition principle. However, when you inject a test signal with frequency ft, the circuit components will convert the source signal frequency fs to ft. So the total signal created by injected signal will be interferered by the source signal. \$\endgroup\$
    – emnha
    Jun 25, 2016 at 10:35
  • \$\begingroup\$ Only if the spectrum of the two signals overlap. If they don't overlap then you can perfectly measure impedance at one frequency in the presense of a different frequency but why bother if you can switch off (conceptually or physically) the interfering signal. \$\endgroup\$
    Jun 25, 2016 at 20:13
My answer in one sentence: When you try to determine the current through the unknown output resistance (caused by a voltage source that is connected at the output node) there must be not another current caused by the input signal.
  • \$\begingroup\$ Thank you. So should we always shortage the input voltage source when calculating output impedance? \$\endgroup\$
    – emnha
    Jun 23, 2016 at 14:57
    \$\begingroup\$ Yes - of course. The voltage-current ratio at the output must be caused by the test voltage (or test current) at the output only. \$\endgroup\$
    – LvW
    Jun 24, 2016 at 6:32
  • \$\begingroup\$ Does Rout is is the one in the model of amplifier output (Avo*Vin in series with Rout)? \$\endgroup\$
    – emnha
    Jun 25, 2016 at 3:21
The reason is that when you try to get a Thevenin equivalent circuit, using the 'test source' method, you set all the independent voltage and current sources to zero. However, you keep the dependent sources intact.
\$V_t\$ is your test source and to find the equivalent resistance looking into that terminal you need to find \$I_t\$. Then \$R_{equiv}=\frac{V_t}{I_t}\$.
  • \$\begingroup\$ Thank you. Could you explain why the current source gm*vgs is not considered there? Is it an independent source in this case? \$\endgroup\$
    – emnha
    Jun 23, 2016 at 5:44
  • \$\begingroup\$ The source is considered - however its value is zero because Vgs is zero. Better: Vgs must be zero becuase the input signal source is shorted. \$\endgroup\$
    – LvW
    Jun 23, 2016 at 9:08
Measuring the output resistance of a circuit is essentially the same thing as measuring its Thevenin resistance. When measuring the Thevenin resistance, all independent sources are turned off. The (small signal) input source is such an independent source so it is turned off -- and turning off a voltage source means setting the voltage across its terminals to 0.
The large signal input source (the bias voltage) sets the dependent current source \$g_{\text{m}} v_{\text{gs}}\$ of the MOSFET because it determines \$g_{\text{m}}\$ and other small signal MOSFET parameters, so it can't be entirely ignored. Once it is used to determine the dependent sources it too is turned off.
Because of the topology of the circuit, 0 input means \$v_{\text{gs}} = 0\$: the MOSFET has ideally infinite impedance looking into the gate, so no current can flow through \$R_{\text{S}}\$ and thus there is no voltage across it. It turns out that the dependent current source \$g_{\text{m}} v_{\text{gs}}\$ is 0 as well.
  • \$\begingroup\$ Could you explain why gm*Vgs is an independent source instead of a dependent source? \$\endgroup\$
    – emnha
    Jun 23, 2016 at 14:58
  • \$\begingroup\$ @anhnha I stated in my answer that \$g_{\text{m}} v_{\text{gs}}\$ is a dependent source. It depends on \$v_{\text{gs}}\$, and in this case we can ignore it only because \$v_{\text{gs}}\$ happens to be 0. It's the input source \$v_{\text{s}}\$ that's independent and set to 0 -- it's the input, so by definition it's independent of the amplifier circuit. The amplifier circuit is stimulated by it. \$\endgroup\$
    – Null
    Jun 23, 2016 at 15:09
  • \$\begingroup\$ Yes, but actually I don't understand why we set Vin = 0 that leads to Vgs =0. \$\endgroup\$
    – emnha
    Jun 25, 2016 at 10:39
Let me cover it all, DC signals are neglected in small signal analysis(when amplitude of signals is quite small) because they cause constant current and provide a bias level, so pretty much neglecting them will be like neglecting a constant in a phase or frequency dependent equation which makes it simpler to understand.
Ok there goes the DC sources
MOSFET have pretty high input impedance means nothing or no current flows through the gate terminal, that is shown by a open(red) at Hybrid-pi model of small signal analysis,
Now we know that the conductance of the channel in the MOSFET is effected by the voltage at the gate terminal, but the input circuit is isolated from the output circuit, this relation is established by concept of transconductance, which is the ratio of change in the drain current to the change in the input gate voltage vgs(where small v and gs represent the small signal nature of the source).
Now comes the superpositioning theorem
Which states that the current from two sources in any branch of the circuit(linear circuits) is independent of other sources, and the resultant current is the algebraic sum of current calculated when individual sources are acting alone.
Hence here by grounding we are removing the effect of the input voltage, which also makes the gm.vgs(where Is=gm.vgs is a dependent current source with dependency upon vgs) acting as a current source zero, hence now we can calculate the sole resistance of the channel by connecting a small signal source vt at the output when the small signal input is zero.
Though the vgs doesn't play a direct role but works as a Transconductance amplifier, hence the effect of other power supply is removed by grounding vgs.
You are considering the small signal model so we have to short all large signals. But in your case you also have a small signal source at the gate(input) . As many have already answered, its just a matter of perspective. You want to measure the output resistance.
Even when you consider any normal circuit in real life and when you have to find the resistance of it with a multimeter. You de-energize all the sources (Short independent voltage sources and open circuit independent current sources) and then measure the resistance. So in your case also you do the same. You could of course have the small signal source \$v_s\$ (large signal source \$V_{bias}\$ should be shorted by any means because you are doing a small signal analysis and all large signals should not be considered) but now if you try to calculate the resistance from the output it would be incorrect because you have other sources influencing the resistance, one case where we need to have it is when we are findinng the transfer function where you need to find the \$V_{out}/V_{in}\$. So to find the output resistance we short the source, since \$V_g=V_s=0\$ and \$V_{source}=0\,(\text{gnd})\$, \$V_g-V_{source}=V_{gs}=0\$. So \$g_m*V_{gs}=0\$, this is what is done in the equations you have mentioned.
Simply, the measured test current would be the sum of the circuit response to both the test voltage and the source voltage, and an incorrect output resistance calculation would result.
The formula you included shows it quite nicely: if vgs ≠ 0, then vt = it(r0||RD) + gm·vgs, and Rout= r0||RD + gm·vgs/it, which gives the wrong result.
  • \$\begingroup\$ Thank you, but that doesn't explain actually how it works. \$\endgroup\$
    – emnha
    Jun 23, 2016 at 5:43
