U3A (OPA703) is used to shift a unipolar DAC signal down to a bipolar signal and feed it to U1 (OPA544). The OPA544 takes this bipolar signal and produce a pretty high current of about 3 Amps at the OUT pin.
In my opinion, U3A is the control stage and U1 is the power stage. I think these two kind of op-amp stages should be isolated, so I created isolated power supplies for them with different GROUND (DGND and AGND).
Does this affect the circuit's operation as a whole?
I used the current source design in LM675 datasheet: www.ti.com/lit/ds/symlink/lm675.pdf
