At first, I am not a hardware professional (starter) so be kind please.
I try to reuse a DENON operation board of a DVD-player with 9 buttons with a Attiny85 Digispark clone connected to PIN3 (see also picture below)
EDIT: About picture: "Sparkfun" must be "Digispark".
However, I can read the values of the buttons, the values seems to be very close so it difficult to detect which button is pressed.
But that's not the main problem/question, the problem is the idle value of analogRead
function which I don't understand. The Arduino (IDE) language manual 'says' that it is a value between 0 and 1023. In this case it reports 654 on idle and above when a button is pressed. Tried also PIN1 and reports 1023 but doesn't detect any input (value doesn't change).
Questions:
- Why does the
analogRead
function reports 654 (also when board disconnected) - Can I increase the resolution of these values to detect buttons more precisely/accurate?
Some code ( I made a USB debugger software solution to debug values via keyboard because there is no UART):
#include "types.h" // Custom types
#include "TrinketHidCombo.h" // Trinket USB lib
#define PIN_BUTTON_IN 3
void setDelay( uint16_t ms ) // usbsafe delay
if( ms < 10 )
{ delay(ms); }
else {
uint16_t iSteps = ms / 4;
while( iSteps-- )
usbIdle(); // We need to do this to keep the Windows USB driver 'sadisfied'
delay(4);
usbIdle();
void usbIdle()
// do nothing, check if USB needs anything done
TrinketHidCombo.poll();
void usbStart()
TrinketHidCombo.begin();
bool usbSendDebugHandshake()
TrinketHidCombo.pressKey( 0, KEYCODE_F24 ); // press
TrinketHidCombo.pressKey( 0, 0 ); // release
setDelay(20);
TKeyboardLEDState recLedState = usbGetKeyboardLedState();
return ( recLedState.caps && recLedState.num && recLedState.scroll );
void usbDebug(const char* s, bool bLineFeed )
static bool bUsbDebugHandshake = false;
static bool bUsbDebugEnabled = false;
if( !bUsbDebugEnabled && !bUsbDebugHandshake )
//bUsbDebugHandshake = true;
bUsbDebugEnabled = bUsbDebugHandshake = usbSendDebugHandshake();
if( bUsbDebugEnabled )
(bLineFeed)?TrinketHidCombo.println( s ):TrinketHidCombo.print( s );
usbIdle();
void usbDebug(const char* s )
{ usbDebug( s, true ); }
void usbDebug( int i, bool bLineFeed )
char buff[10]; //the ASCII of the integer will be stored in this char array
memset(buff, 0, sizeof(buff));
//itoa(i,buff,10); //(integer, yourBuffer, base)
usbDebug( itoa(i,buff,10), bLineFeed );
void usbDebug( int i )
{ usbDebug( i, true ); }
TKeyboardLEDState usbGetKeyboardLedState()
uint8_t iState = TrinketHidCombo.getLEDstate();
TKeyboardLEDState tResult;
tResult.caps = (iState & KB_LED_CAPS);
tResult.num = (iState & KB_LED_NUM);
tResult.scroll = (iState & KB_LED_SCROLL);
return tResult;
// Setup and main routine
void setup()
usbStart(); // First priority, start the USB device engine and enumerate
pinMode(PIN_BUTTON_IN , INPUT );
void loop() // Main program - main()
// Button pressed?
int iButton = analogRead(PIN_BUTTON_IN);
usbDebug( "PRESSED: ", false );
usbDebug( iButton );
setDelay(1000);
