Hi there,
I was trying to do something and not sure what I did without knowingly those small green circles along with names has appeared on ever pin of all the components I had in the schematics.
Could you please let me know how to hide/delete them.
Simply run the following command in the schematic window:
display -pins
If you want to view them again:
display pins
As is the way with Eagle, you can also do it from the toolbar. Simply click on the visible layers/display button, find layer 93 (Pins) and hide it by clicking the number so it is no longer blue. Then click OK.
Hide Pins Layer
  • \$\begingroup\$ Thank you very much Tom. Thought I messed up with the net label settings.And I was trying to find that command in the Eagle doc but your reply saved time. \$\endgroup\$
    – Dee
    Jun 23, 2016 at 12:52
  • \$\begingroup\$ Oh yeah now I got it. Probably I might have disabled it unknowingly. Good find. \$\endgroup\$
    – Dee
    Jun 23, 2016 at 12:57
  • \$\begingroup\$ This also hides the green circles, which are pretty nifty to be able to see, as well as the labels. \$\endgroup\$ Jun 23, 2016 at 16:28
