-5
I'm trying to fix my TRRS type headphones but I can't tell the difference between these five wires.
-Blue -Red -Green -Copper (red-ish?) -Black
closed as off-topic by PeterJ, Leon Heller, Bence Kaulics, dim, Brian Drummond Jun 27 '16 at 9:45
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – PeterJ, Leon Heller, Bence Kaulics, dim, Brian Drummond
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Make a nick in the wire jacket and beep it out with a multimeter. \$\endgroup\$ – Daniel Jun 26 '16 at 23:21
  • \$\begingroup\$ Consider this question. Voted to close due for off topic: repair. \$\endgroup\$ – user2943160 Jun 27 '16 at 2:22
  • \$\begingroup\$ @Daniel modern headphone wires are sometimes very non-trivial to strip :) \$\endgroup\$ – rackandboneman May 12 '18 at 22:29
Wire color isn't standard. Never trust wire color. Always use a continuity tester to find which wire goes to which conductor.
    \$\begingroup\$ +1. In a batch of 50 nominally identical headphones, same part number, purchased at the same time, I found four or five different colour coding standards used. \$\endgroup\$ – Brian Drummond Jun 27 '16 at 9:44
