-1
This question already has an answer here:
I'm trying to repair my headphones with a broken jack. I just purchased a replacement TRRS jack, and now my problem is knowing the function of the five different wires in my earbuds. How can I use a multimeter to do this? Thank you in advance.
marked as duplicate by uint128_t, PeterJ, Bence Kaulics, Bimpelrekkie, dim Jun 28 '16 at 8:24
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
Touching the ohmmeter to the pair of wires going to each earbud and ground should cause an audible pop and show low impedance. The remaining non-ground wire would be for mic. See Fixing a headset, TRRS
  • \$\begingroup\$ I just tried this and I can't seem to hear any audible noise. Does one lead need to be touching the ground wire and the other lead a different wire? I did this for each wire with no luck. Could it be the setting my Ohm Meter is on? \$\endgroup\$ – Brandon R. Jun 27 '16 at 22:41
  • \$\begingroup\$ It is the current through the speaker that causes a pop, so you need one lead on the audio and the other on the return. Depending on wiring, the return may be common or separate for the two sides. \$\endgroup\$ – stark Jun 28 '16 at 0:40
