I am working on a latching push-on/hold-off circuit for a momentary button and I am stuck with determine which type of capacitors to use. The circuit is detailed below (originally from Mosaic Industries):
I am unsure whether or not this will work with electrolytic capacitors, and if it will which polarity should they be? I have considered ceramic capacitors, but I am unable to easily source 1uF ceramic capacitors. As the schematic does not indicate that they are polarised capacitors I suspect that ceramics are the only option, but if this is the case what value would be ideal given I can only find values less than 1uF.
For this circuit I am using a CD4011 NAND IC.
Any advice is greatly appreciated.
