I am planning to use TI TLV61220 in one of my designs. My design will be in sleep most of the time & the current in sleep mode is 10-20 uA. In active mode, it wil take max 10mA.
The device is powered from a CR123A battery which operates @ 3V down to 2.3V. I am stepping this voltage up to 3.3V fixed. I am planning to use TLV61220 for this purpose.
The datasheet says "Minimum Switching current - 200mA". Can some one clarify what it means?
The datasheet is :-
http://www.ti.com/lit/ds/symlink/tlv61220.pdf
| improve this question | | | | |
  • 6
    \$\begingroup\$ Please read the 10.3.1 Controller Circuit section on page 10, and update your question if you still do not understand. Also this IC is not an LDO but a switching regulator with boost topology. \$\endgroup\$ – Bence Kaulics Jun 28 '16 at 10:45
  • \$\begingroup\$ You need to find a circuit with pulse skipping, burst mode or similar to pull this off. \$\endgroup\$ – winny Jun 28 '16 at 12:09
  • \$\begingroup\$ @Bence Kaulics :- Yes, I read that but could not completely understand. Can you share some reference Document to understand the concept? \$\endgroup\$ – Oshi Jun 28 '16 at 13:13
