http://www.nxp.com/documents/data_sheet/PCF8575.pdf
Can somebody tell me which parameter one should look for while looking for calculating maximium Current source/sinked by a pin.
The output current is listed as IOL and IOH:
PC8575 output current
Please note that these are the values that guarantee not to exceed the specified voltage drop (VOL, VOH). If you need a smaller voltage drop, you need to use a smaller current. (See also What is drive strength a measurement of?)
