I would like use an accelerometer equipped device to record a motion trajectory, as high-resolution and low-noise as possible. For instance, let's say I run a jogging route of 6 kilometres, returning exactly back to the location I started from. So I have the idea that I could possibly do without a GPS module and just record at constant rate the data from an accelerometer, say an ADXL345.
My questions thus:
- can I use a 3-axis accelerometer to integrate twice, from acceleration to velocity to distances?
- if the constraint is that I return to the exact location from where I started, can I apply an error-correction to the trajectory that compensates for drift, so that the last (x,y,z) coordinate of the recorded and integrated data becomes identical to the first one?
- say I run from location A to B and back to A again. If I apply the mentioned drift-correction, do I still have a meaningful/correct position of spot B?
If not, how would I achieve this? Do I have to combine the accelerometer with a GPS?
