I hope to repair a p.c.b. for a hard disk drive, which has a burnt out SMD component (by mistakenly connecting the supply back to front -- I had to guess and got it wrong), 2010 size, a connection at each end, with a polarity(?) line at one end . It has "ON" in a circle, and "QA" and "R 846 ." written on it.
I have searched on line with no success, so please can anyone identify this component?
closed as off-topic by uint128_t, Matt Young, Bence Kaulics, Dmitry Grigoryev, Daniel Grillo Jul 6 '16 at 11:50
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – uint128_t, Matt Young, Bence Kaulics, Dmitry Grigoryev, Daniel Grillo
If this question can be reworded to fit the rules in the help center, please edit the question.
  • 6
    \$\begingroup\$ A photo would give much more info than just the text on the part. \$\endgroup\$ – brhans Jul 5 '16 at 18:15
  • \$\begingroup\$ ON in a circle usually means those guys, maybe you should search on their website. \$\endgroup\$ – Dmitry Grigoryev Jul 6 '16 at 10:28
  • \$\begingroup\$ Not sure why this was closed. Component identification frequently comes up and is pretty much always on topic. \$\endgroup\$ – Tom Carpenter Jul 6 '16 at 15:25
  • \$\begingroup\$ Indeed, the user doesn't ask for repair help. That's just to give some context to his question. \$\endgroup\$ – pipe Jul 13 '16 at 8:01
From your description of the component, and how it failed, it is this NSA5.0AT3G OnSemi 5 V TVS diode. Of course the photo from you will help confirm this.
These TVS diodes are common on hard drive PCBs. Common reasons for them to fail include sustained overvoltage (e.g. 12 V supply connected to 5 V input) or reverse polarity connection (as in your case).
Another way for you to confirm the component identification, is to reverse-engineer the function of that burned component on the PCB, by following the PCB traces from the drive's power connector. A TVS diode would be placed directly across the power input (with possibly a fuse or similar in series). Based on it being a 5 V TVS, it would be placed across the 5 V input of course (not the 12 V input, if yours is a 3.5" drive which uses that; 2.5" drives don't use 12 V power).
Beware that you might also have additional damage to that hard drive, including:
  • damaged PCB track, due to the high current flow through the diode while it was conducting (not all manufacturers include fuses or similar in series with the TVS diodes on these PCBs), and/or a blown fuse or similar (if fitted);
  • other damaged electronic component(s) on the PCB, especially if the full reverse voltage reached them for an extended period e.g. if the TVS failed open-circuit (or a fuse "opened" and disconnected the TVS) with the reverse voltage still applied;
  • damaged head(s), as they are very sensitive to reverse or excess voltage.
(The QA component marking is confirmed on page 1 of that linked OnSemi PDF, but I'm currently on a mobile so adding an image of that will be delayed until I'm back on a bigger screen & keyboard.)
