I am now designing one four layer analog board for 24-bits ADC based bio-potential signal acquisition. I have ground and power plane on the second and third layers. Most of the analog signal traces are on the top layer. The ground plane is on the second layer.
The frequency of the board is about 1.5Hz to 3.79kHz. Board size is about 4"x5". The ADC I am using is the ADS1298 from TI, with analog front-end by op-amps and instrumentation amplifier.
My question is should I pour ground on the open area of top and bottom layers? Will that do anything good to the signals? or that will make them worse?
  • \$\begingroup\$ And the frequency is? \$\endgroup\$ Jul 5, 2016 at 19:28
  • \$\begingroup\$ 1.5Hz ~ 3.79kHz \$\endgroup\$ Jul 5, 2016 at 19:38
    \$\begingroup\$ At those frequencies it probably won't make the slightest bit of difference. \$\endgroup\$ Jul 5, 2016 at 19:40
    \$\begingroup\$ The correct answer will always be It Depends. The more information you can add to your question, the better answer people can give you. For example, now you added the frequency requirements. Ideally, you would add information about your ADC, maybe the schematics, board size, if you plan to mount it in a shielded box, etc. The more info, the better answer. \$\endgroup\$
    – pipe
    Jul 5, 2016 at 19:44
    \$\begingroup\$ If you are after low noise you should be careful about which power planes go under which signals (including the ground, especially if it is carrying unbalanced digital currents). \$\endgroup\$ Jul 5, 2016 at 19:48
The real question is would adding small 1pf-0.01pf capacitors to ground all around my signal trace to ground help? The answer is not really. Sometimes you will need copper pours for super high impedance inputs such as the inputs to the INA116 or OPA129, they have a guard trace that runs around the signal to keep leakage through the PCB. RF is another thing you would have to shield from. A better way to design for low noise in an analog signal chain is to do this:
Select the right op-amp for the first stage amplifier, filter correctly, and minimize your noise in your signal band pass. Once you have the signal amplified, it doesn't really matter, a 100nV's of noise is nothing to 5V or whatever your rail is. The key is to watch the signal at the input of the board, if you want to be a good low noise pcb designer, think about the pcb in parasitic terms. IE: traces have capacatance between them, and other layers and the pcb also has resistance, it is quite high but still there. A good book is Electromagnetic Compatibility Engineering by Henry W. Ott, that will help you work out the details.
The pours will make soldering hard. In your application it's most important to procide very good shiled to signal (RF grade) from electrode to adc, and also to provide cleanest possible power supply. Of you just do it carefully, it will work fine. Consider antialiasing filter. Are you sure about bandwidth? Seems a little high to me.
