Hello I have this inverter circuit I made that is connected to a button when the button is on one led is on and the other is off and vice-versa.
What should happen is that when the button is pressed voltage flow to one led AND to the transistor base, but it only goes to the transistor base. What am I doing wrong?
Thanks for the help everyone but I found a solution ill post it for people with the same problem in the future. I used a resistor calculator I found on the web and changed R3 to 150 ohms, removed R5 and added a 330 ohm resistor before D1. Thanks for the help anyway!
