I'm laying out a mixed signal PCB and I'm trying to decide between (1) separating the ground planes for the digital and analog/digital circuits completely [shown in top figure] or (2) keeping the two planes mostly separated [shown in the bottom figure]. The lines in the middle of the figure represent digital wires that carry data to and from the analog/mixed circuits.
I don't like (2) very much from a CAD perspective because then you can't have separate nets for AGND and DGND. Is there some reason not to go with (1), in terms of noise performance? Is there a better way to keep the digital noise away from my precious analog circuits?
  • \$\begingroup\$ There is no one good answer to this question - it always depends on thousands variables, like analogue signal frequency, bandwidth, level, source impedance, noise from other components, noise form environment, recommendations from datasheets of analogue parts... and many, many other. \$\endgroup\$ Jul 7, 2016 at 5:42
  • \$\begingroup\$ This is a good question but it has already been asked electronics.stackexchange.com/search?q=analog+digital+ground \$\endgroup\$
    – Voltage Spike
    Jul 7, 2016 at 18:29
In Altium you can use a component called a "net tie" to physically connect two nets in a layout without actually merging the two nets into one. Other CAD tools may provide similar capabilities.
Your option (1) forces the return currents for the digital signals to find a long path back from load to source. This means the complete signalling circuit will encompass a relatively large loop, which can result in coupling to other circuit loops and/or emissions.
Your option (2) is one way.
You could also provide a capacitive path between the two ground nets near where the digital signals cross. However this can still cause some crosstalk between the digital signals due to the shared constricted return path.
You could also use an isolating device such as an optocoupler or transformer to carry each digital signal across the gap between the two ground planes. Normally, due to cost, you'd only use this technique if you need to allow for substantial voltage difference between the two ground nets.
