I am using pj-102ah dc barrel jack. I am not sure if this is a mistake in the dimensions, or you can correct me if I am wrong. the top left red circle shows the the length of the three pins which is 1mm, while the bottom red circle shows the length X width which is 1mm X 1.6mm. How come the width is more than the length, and it seems wrong even from the real picture of the jack.
I updated the footprint as shown in the picture above, where the white squares represent the drills for the pins.
    \$\begingroup\$ pin width: 1mm & thickness:?, hole width: 1.6mm & thickness: 1mm \$\endgroup\$
    – Wesley Lee
    Jul 6, 2016 at 23:42
  • \$\begingroup\$ @WesleyLee : ok, it make sense. \$\endgroup\$ Jul 6, 2016 at 23:47
    \$\begingroup\$ If your PCB manufacturer doesn't support rectangular cutouts on this scale, you should start with 1.60mm diameter round holes, then check fit and alignment requirements for later board revisions. \$\endgroup\$ Jul 7, 2016 at 0:10
  • \$\begingroup\$ @user2943160 : I updated the my question, is that what you mean ? \$\endgroup\$ Jul 7, 2016 at 0:20
    \$\begingroup\$ @AbdelrahmanElshafiey I was just giving unsolicited, related advice since a lot of PCB manufacturers don't support square cutouts. Not looking too closely, but your footprint looks reasonable. \$\endgroup\$ Jul 7, 2016 at 0:25
It looks correct to me. But I can see the reason for the confusion. The PCB layout diagram should have been rotated 180 degrees so it would be more obvious.
The 1mm width of the flat pins would fit with plenty of clearance against the 1.6 mm length of the rectangular hole. The thickness of the pin (not specified) will clear the 1mm hole width.
A 1.6mm round hole should meet the spirit of the spec. Would just need more solder than a rectangular hole.
