I'm developing an USB application for a STM32 MCU.
For now I have 2 interfaces for CCID classes and I want to add another for a Virtual COM Port. On a STM32F4, The limit of IN endpoint in FullSpeed is 5 plus one reserved for control (80). I already used 4 IN endpoint for the CCIDs.
Does Interupt IN for CDC class is optional?
I think i have to declare 3 endpoints like this:
  • Bulk IN
  • Bulk OUT
  • Interupt IN
Note : I know that in HighSpeed there is 7 endpoint available but i don't have time to develop a custom board (need an external phy chip and other things).
  • \$\begingroup\$ Just a side note: On STM32, you need an external PHY with the USB HS only if you actually want it to run at high-speed. If full-speed is sufficient, you can use the integrated full-speed PHY of the USB HS peripheral (there is one). \$\endgroup\$ – dim Jul 7 '16 at 7:43
  • \$\begingroup\$ The CDC specification says that the notification endpoint is optional. \$\endgroup\$ – CL. Jul 7 '16 at 7:44
The notification endpoint is optional, as CL said, however I wouldn't count on proper driver support.
  • \$\begingroup\$ I will try without Notification endpoint for now. If it really not supported by the windows driver i will use @dim's solution anyway. \$\endgroup\$ – user2740652 Jul 7 '16 at 9:15
