Could you please explain why the V(R1) is not 2V?
I'm studying boost converter using LTSpice. According to theory the output voltage of this circuit should be determined by the duty cycle of the square wave which is generated by the switch. Here I used 50% and expected that the Vout would be 2*Vin. But the simulation results in this.
From this simulation I found that the Vout is dependent of L, C and R. Is that true? I don't understand what is wrong.
