A TLC5940 can sink up to 120ma per channel. I am having difficulty finding the max current for the entire chip on the Datasheet. Is there one, or is there another limiting factor for this chip?
Additional Hypothetical Question: If I try to drive 10 LEDs (each with a voltage drop of 3.2) in series, with 38 Volts, will the voltage be dropped to 4 volts before the current enters the chip?
Also, I neglected to mention that my LED's are 4 prong RGB LEDs. I will be unable to wire them all in series. Them must be wired in parallel.
***Personal Tests ==============
I have been able to power over 50 LED using this chip without an issue. to do this, you must make sure that each group of series LEDs on a channel (The chip can control 16 groups via 16 channels via 16 pins) drops as much voltage as possible (between the positive connection and the chip.) For example, if you are using a 9 volt power supply, and LEDs with a 2 volt drop, each channel should have 4 LEDS in series, plus some resistance to drop most of the remaining 1 volt. A good way to find the best value for the resistor is to build your LED circuit with a potentiometer, and use it find the resistance value at which the LEDs start to dim.
Also, if you want to use a TLC594x chip, read this article about additional issued which you need to be aware of:
Test Update ==============
I am testing this chip with 8 different LED configurations:
A) One LED only
B) One LED in series with a 10ohm resistor
C) One LED in series with a 220ohm resistor
D) Three LEDs in series
E) Three LEDs + 10ohm resistor in series
F) Three LEDs + 220ohm resistor in series
G) Three LEDs in parallel, each in series with a 10ohm resistor
H) Three LEDs in parallel, each in series with a 220ohm resistor
Note: brightness is given in ranked order, higher numbers are brighter
Source set to 6.7 ma. Chip slightly warm to the touch
A) volts dropped: 2v[LED]0v
Bright: 2
B) volts dropped: 2v[10ohm]1.9v[LED]0v
Bright: 2
C) volts dropped: 3.4v[220ohm]1.9v[LED]0v
Bright: 2
D) volts dropped: 5.7v[LED]3.9v[LED]2v[LED]0v
Bright: 2
E) volts dropped: 5.7v[10ohm]5.6v[LED]3.8v[LED]1.9v[LED]0v
Bright: 2
F) volts dropped: 7v[220ohm]5.5v[LED]3.7v[LED]1.9v[LED]0v
Bright: 2
G) volts dropped: 1.7v[10ohm]1.7v[LED]0v
Bright: 1
H) volts dropped: 2.2v[220ohm]1.7v[LED]0v
Bright: 1
Source set to 11.3 ma. Chip comfortably hot to the touch
Bright: 2
B) volts dropped: 2.1v[10ohm]2v[LED]0v
Bright: 2
C) volts dropped: 4.5v[220ohm]2v[LED]0v
Bright: 2
D) volts dropped: 6v[LED]4v[LED]2v[LED]0v
Bright: 2
E) volts dropped: 5.9v[10ohm]5.8v[LED]3.9v[LED]2v[LED]0v
Bright: 2
F) volts dropped: 8.3v[220ohm]5.8v[LED]3.9v[LED]2v[LED]0v
Bright: 2
G) volts dropped: 1.8v[10ohm]1.7v[LED]0v
Bright: 1
H) volts dropped: 2.6v[220ohm]1.7v[LED]0v
Bright: 1
Source set to 16.9 ma. Chip almost painfully hot to the touch
A) volts dropped: 2.1v[LED]0v
Bright: 2
B) volts dropped: 2.3v[10ohm]2.1v[LED]0v
Bright: 2
C) volts dropped: 5.8v[220ohm]2.2v[LED]0v
Bright: 2
D) volts dropped: 6.2v[LED]4.2v[LED]2.1v[LED]0v
Bright: 2
E) volts dropped: 6.2v[10ohm]6.1v[LED]4.1v[LED]2.1v[LED]0v
Bright: 2
F) volts dropped: 9.1v[220ohm]6.1v[LED]4.1v[LED]2.1v[LED]0v
Bright: 2
Bright: 1
H) volts dropped: 3v[220ohm]1.8v[LED]0v
Bright: 1
Source set to 21.1 ma. Chip touchable but too hot for sustained contact
A) volts dropped: 2.3v[LED]0v
Bright: 2
B) volts dropped: 2.5v[10ohm]2.3v[LED]0v
Bright: 2
C) volts dropped: 6.8v[220ohm]2.3v[LED]0v
Bright: 2
D) volts dropped: 6.4v[LED]4.4v[LED]2.3v[LED]0v
Bright: 2
E) volts dropped: 6.6v[10ohm]6.3v[LED]4.2v[LED]2.3v[LED]0v
Bright: 2
F) volts dropped: 9.2v[220ohm]6.0v[LED]4.1v[LED]2.2v[LED]0v
Bright: 2
G) volts dropped: 1.9v[10ohm]1.8v[LED]0v
Bright: 1
H) volts dropped: 3.4v[220ohm]1.8v[LED]0v
Bright: 1
Additional test 1:
source set to 21ma
9.4 volt max supply
PWM set to max
8 channels used
4 LEDs in series per channel
no additional resistance
voltage drop per channel: 7.8 volts
32 LEDs total
total current 150ma
Chip is only slightly warm
Note: 80 ohms can be added in series to a channel without lowering the brightness.
