As you all probably know, capacitances in BSIM3v3 are just the partial derivatives of the terminal charges with respect to the terminal voltages. They are not physical two terminal capacitors.
Cij = dQi/dVj.
For a MOSFET, we have Cgs, Cgd, Csg, Cgg,...
Because they are not physical two plates capacitor, how do you convert these capacitances to physical value for hand calculation?
For example, Cgs as formula above is not the total equivalent capacitance between Gate and Source. How do you calculate total real Cgs? Also, how do you use these partial derivatives for hand calculation?
Use the method described in the link to do the hand calculation:
Approximate models for hand calculations
But do not expect very accurate results using hand calculations, especially for short channel lengths (L < 2u)
Or read this:
Capacitance Modeling
  • \$\begingroup\$ Thank you. However, this lecture doesn't guide onto how to use BSIM3v3 capacitances in calculating real capacitance. \$\endgroup\$
    – emnha
    Jul 9, 2016 at 6:45
  • \$\begingroup\$ I added another link which discusses BSIM3v3 specifically. \$\endgroup\$ Jul 9, 2016 at 6:52
  • \$\begingroup\$ Yes, but I already read that a lot before. The problem in BSIM3v3 is that it only explain models not how is it used for hand calculation. \$\endgroup\$
    – emnha
    Jul 9, 2016 at 7:45
