-1
I have a mobile front camera (like this one). I want to build a wearable camera out of it (like this one). However I want to make this from scratch and not have to resort to using a Raspberry Pi.
These are my requirements:
  1. Take a photograph every fixed interval
  2. Store it to a micro-SD card
  3. Should be able to connect to PC via USB
  4. (advanced/optional): Process images online and convert the raw file to a low resolution grey scale image.
So here are my questions:
  1. What kind of processors will I need?
  2. Is there an easier camera to work with? I want the size to be small.
closed as too broad by Bence Kaulics, Sparky256, uint128_t, dim, Daniel Grillo Jul 11 '16 at 11:37
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Is this for video or just still images? \$\endgroup\$ – user110971 Jul 10 '16 at 16:14
    \$\begingroup\$ How much work do you really want to do for this when a rPi is the single-board-computer solution that can do it for you? Also, getting the iPhone camera's mating connector may be difficult and will require soldering a component with tiny pins. \$\endgroup\$ – user2943160 Jul 10 '16 at 16:33
    \$\begingroup\$ Does "like this one" imply "I have exactly this camera model"? Or "I have a small camera with some flat cable"? The point is that though there are a few camera interface standards, it's not clear whether your camera follows one of these. \$\endgroup\$ – Marcus Müller Jul 10 '16 at 16:50
It is easier to get a raspberry pi and its camera module and play with it. To answer your question: You need an ARM processor with DSP capability. A cortex-M7 will do.
  • \$\begingroup\$ You mean cortex-M7? I think that, more important than DSP capabilities, the MCU requires a camera interface, because you definitely don't want to bit-bang this. And I actually wonder how this question is answerable, since we don't even know what kind of interface the camera specified by the OP uses. \$\endgroup\$ – dim Jul 10 '16 at 22:12
  • \$\begingroup\$ Yes Cortex M7. I fixed the typo. For camera interface we need to use DMA and that is very hard to get it right. I worked for one month day and night on a STM32F camera module and could not get it right. DMA programming and all those low level interrupts are though. But I appreciate the op enthusiasm. He should give the ARM a try. \$\endgroup\$ – Ehsan Jul 11 '16 at 2:40
  • \$\begingroup\$ What I've used is sensor -> FPGA-> DSP. You get a lot of data with a camera. 1M sensor @ 25fps outputs 600mbps. It is quite involved to make it work on a processor, but the smallest FPGAs can handle that. \$\endgroup\$ – user110971 Jul 11 '16 at 13:51
  • \$\begingroup\$ yes he can use ARM processor on FPGA. \$\endgroup\$ – Ehsan Jul 11 '16 at 15:58
