-1
I came up with this simple circuit to drive a couple of PC fans ON and OFF from a Raspberry Pi's GPIO pin:
TIP122_as_fan_switch
Probably I need a flyback diode somewhere, but at this point I don't know where and how to choose it (and if it's really necessary).
Any hint? Thanks.
EDIT: (if may help) I noticed that the fans are "brushless"... Does it mean I can go without diode?
    \$\begingroup\$ you need a diode between the +12V rail and the collector, with the anode towards the +12v. If these are simply case fans, you will not need a diode, as the fans will have them built in. \$\endgroup\$ – user86234 Jul 12 '16 at 16:17
    \$\begingroup\$ @tuskiomi I would still add a diode: it's a cheap insurance, and it doesn't hurt anything. Use a fast Schottky diode. For a moderately sized PC fan, I use B340 (or some such Schottky diode rated for 2A to 3A). Don't use 1N4001, because they are too slow for a flyback diode. \$\endgroup\$ – Nick Alexeev Jul 12 '16 at 16:29
  • \$\begingroup\$ Thanks guys. In addition, I noticed that the fans are "brushless"... Does it mean I can go without diode? [updating the question] \$\endgroup\$ – dentex Jul 13 '16 at 7:24
    \$\begingroup\$ If you are only making a small number, e.g. one I'd add the diode it costs almost nothing and does no harm. \$\endgroup\$ – Warren Hill Jul 13 '16 at 7:32
  • \$\begingroup\$ We communicate circuits with schematics here, not cartoons. \$\endgroup\$ – Olin Lathrop Jul 13 '16 at 11:11
You need a flyback diode?
The answer is yes.
The equivalent (simplified) circuit of a BLCD motor is:
You have a inductance and thus you need a flyback diode.
Usually you need to put a diode across the coil, as tuskiomi said in comment.
Some useful links:
  1. This is exactly your circuit
  2. A question that explain diodes in this circuits
  3. Another similar question
  • \$\begingroup\$ Grazie tante :) \$\endgroup\$ – dentex Jul 13 '16 at 13:18
