I'm doing some coding on an STM32F411 board, used the CubeMX & HAL Libraries for laziness.
I'm trying to get the windowed watchdog (WWDG) up & running, and doing the very basic version (non interrupting) works as expected using this sequence of setting up (straight from the HAL/CubeMX):
/* Reset of all peripherals, Initialises the Flash interface and the Systick. */
HAL_Init();
/* Configure the system clock */
SystemClock_Config();
/* Initialise all configured peripherals */
MX_GPIO_Init();
MX_ADC1_Init();
MX_I2C1_Init();
MX_IWDG_Init();
MX_TIM1_Init();
MX_USART6_UART_Init();
MX_USB_OTG_FS_USB_Init();
MX_WWDG_Init(); // Window == count == 0x7F
HAL_WWDG_Refresh(&hwwdg, 0x7F);
HAL_WWDG_Start(&hwwdg);
while(1)
//main loop stuff
This works as expected (I will narrow the window later), but if I change the code to use the "early wakeup" interrupt function (EWIF) - again, all auto-generated from CubeMX - it instantly fires the interrupt:
HAL_Init();
MX_GPIO_Init();
MX_ADC1_Init();
MX_I2C1_Init();
MX_IWDG_Init();
MX_TIM1_Init();
HAL_WWDG_Start_IT(&hwwdg);
while(1)
//main loop stuff
The MX_WWDG_Init();
call in this case includes the lines to set NVIC / enable IRQ but is otherwise identical:
void HAL_WWDG_MspInit(WWDG_HandleTypeDef* hwwdg)
if(hwwdg->Instance==WWDG)
/* USER CODE BEGIN WWDG_MspInit 0 */
/* USER CODE END WWDG_MspInit 0 */
/* Peripheral clock enable */
__HAL_RCC_WWDG_CLK_ENABLE();
/* Peripheral interrupt init */
HAL_NVIC_SetPriority(WWDG_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(WWDG_IRQn);
/* USER CODE BEGIN WWDG_MspInit 1 */
/* USER CODE END WWDG_MspInit 1 */
I tried adding __HAL_WWDG_CLEAR_FLAG(hwwdg, WWDG_FLAG_EWIF);
just before the __HAL_WWDG_ENABLE_IT(hwwdg, WWDG_IT_EWI);
call in HAL_WWDG_Start_IT(&hwwdg);
but it makes no difference.
What have I missed here?
