For example,
The resistor above has four colors. Green, blue, red, gold.
My calculation says its value is 562 ohms +-10%. But this page says its value is 5.6K-1/4W. What is my mistake?
    \$\begingroup\$ the 2 stands for the number of zeroes, so "56 0 0" aka 5600 aka 5k6/5.6k \$\endgroup\$ – Wesley Lee Jul 14 '16 at 16:14
    \$\begingroup\$ With your system, how would you indicate any resistance over 999 ohms? \$\endgroup\$ – brhans Jul 14 '16 at 16:25
The third band (adjacent to the tolerance band) is a multiplier. This means that it is the number of zeroes after the first two digits. For example, a brown-red-orange-gold resistor would be 1 2 000 (three zeroes, since orange stands for 3) ohms.
For the record, a gold band means 5%, not 10%.
It is 5.6K 5%. The first two bands give you the value (56), the third is the multiplier (10^2) so 100 * 56 = 5600\$\Omega\$, and the final band is the tolerance (gold = +/-5%).
Well, in this 4 band resistor, the 4th band is actually % rating, as you guessed. However depending on how you google for tables, you have to search for "3 band resistor table" (yes, its confusing.. maybe the 4th band was an addendum/optional?).
So the first two bands represent algarisms, and the third represents an "n" multiplier (10ˆn).
So the value is given by:
[("band 1" *10) + (band 2)] * 10ˆ(band 3).
[50 + 6] * 100 = 5600, aka 5.6k, aka 5k6.
Or more roughly put:
Band 1 = algarism 1
Band 2 = algarism 2
Band 3 = amount of zeroes
In a resistor with 5 color bands (the 5th being %), the same applies, but the first 3 bands are algarisms and the 4th is the multiplier.
