I am attempting to simulate a flyback controller from TI, part number UCC28700-Q1, datasheet here: http://www.ti.com/lit/ds/symlink/ucc28700-q1.pdf
I have downloaded the SPICE model from TI (as can be found here: http://www.ti.com/lit/zip/slum455) and am now attempting to build a SPICE simulation in LTSpice.
If I open the model in LTSpice, I can right click the .SUBCKT line and let LTSpice auto draw the symbol for me. When I do so, I get a 6pin block with the pins labelled as: P1 P2 S1 S2 RS1 RS2. These pin names do not match up with anything I can see in the datasheet, and I don't believe that the order of the pins matters in terms of relationship between SPICE model and real world. If I try and draw the symbol myself, I end up with the same issue, as I still don't know how these pin names relate to the signals.
Is there a simple way to work out which pin is which?
