I am trying to play around with beta ratio effect of CMOS inverter. To do so I need to have parameterized subcircuit so I can adjust the ratio of PMOS beta over NMOS beta and achieve HI-skewed or LO-skewed inverters.
How do you define parameter x in a sub-circuit?
What I need to do is to define a sub-circuit like this:
.subckt inverter_035_x in out VDD GND
XM1 out in 0 0 NM W={x*1u} L=0.35u
XM2 out in VDD VDD PM W={x*3u} L=0.35u
.ends inverter_035_x
and then set x in every instance of the subcircuit so I can achieve different transistor width per instance.
How to set x and pass it to a sub-circuit instance?
  • \$\begingroup\$ ok I figured it out. Just needed to right click and type 'x=2' in PARAM field from the main block to pass the x set 2 to the sub-circuit. \$\endgroup\$ – Ehsan Jul 16 '16 at 0:33
  • \$\begingroup\$ Make that comment an answer instead and mark it as answered. \$\endgroup\$ – winny Jul 16 '16 at 9:42
  • \$\begingroup\$ ok I will do that. \$\endgroup\$ – Ehsan Jul 16 '16 at 14:59
