I'm trying to connect a simple reed switch to my Raspberry to check if my door is open or not. I found plenty of tutorials online, but all of their schematics behave different, so I decided to create one myself and check if it seems resonable.
My first test simply lights up a LED when the switch lets the current flow. As my LED is 2V 20mA, a resistor of (3.3-2)/0.02 = 65 Ohm should be enough, but I only have 100 Ohm, it should be ok right?
The next step is to capture the switch event in the GPIO 5 listening for 3.3v input.
I want a max current of 1mA to flow through my pin, so I pick a resistor of around 3k Ohm. Say 5k for safe purposes.
Here is the problem. On every example I found around, the most common used resistor is 10k, and it's always something like this:
Why do I need such a big resistor? And why should I wire to GND too if my GPIO receives a resonably amount of Voltage and current (or 0 when the switch is off)?
Thanks in advance.
    \$\begingroup\$ If you don't put a resistor between GND and GPIO the digital input will not be zero when the switch is NOT connected, It will be high impedance. \$\endgroup\$
    – SMA.D
    Jul 16, 2016 at 6:38
That will be fine.
The next step is to capture the switch event in the GPIO 5 listening for 3.3v input. I want a max current of 1 mA to flow through my pin, so I pick a resistor of around 3 k-ohm. Say 5k for safe purposes.
You are getting mixed up at this point.
Figure 1. A typical micro-controller input with optional internal pull-up resistor.
The input impedance (resistance) of a GPIO pin is very high. If you connect it to the V+ it might draw a couple of micro-amps even with no resistor present. This makes it very sensitive to stray voltages or electro-magnetic fields and, if not addressed, can result in random switching of the input on and off. The way to solve it is to add a pull-up or pull-down resistor of sufficiently low resistance to do the job. 10k is usually a good balance between being sufficiently low and not so low that we're wasting power by increased current through it.
The need for pull-ups is so common that most manufacturers include them internally with a configuration option to enable them.
In your third diagram you have the switch on the "high side" which means that you need a pull-down resistor. If the chip doesn't have an internal pull-down you'll have to add an external one. 10k should be fine.
For example in picture 3 the GPIO has set a pull-up resitor and when the switch is turned off, the GPIO will source the current 5V/10k=0.5mA and it will read as logic 0. When the switch is on, the potential of GPIO will be 5V, therefore no current will flow, the GPIO will read a logic 1.
The picture 2 is rapresenting same thing with GPIO's pull-down resistor enabled (if exists). A basic rule is that a GPIO sholud not have a floating wire acting as antenna, so always you have to "connect" a pull-up or pull-down resistor.
Example in pic 1 is not possible, because of excessive current that MCU would have to sink.
This is how to wire your switch and LED to MCU. Enable the pull-down resistor as well for better noise surpression.
  • \$\begingroup\$ So i Should upgrade the resistor? I did calculate that value for the led voltage drop, how should i calculate it then? \$\endgroup\$
    – lateralus
  • \$\begingroup\$ And could you explain a little more this? "The picture 2 is rapresenting same thing with GPIO's pull-down resistor enabled (if exists)." \$\endgroup\$
    – lateralus
    Jul 16, 2016 at 6:50
    \$\begingroup\$ @lateralus You have to define the proper potential for GPIO when the switch is turned off. This is done with in-built pull up/down resitiors (if your MCU have ths possibility) or adding an external resistor. The example 3 already has an external resistor, so pull up/down is not needed. Example 2, when switch is off, the GPIO is floating, so has no defined state. It will read 0 or 1 whatever noise it will pick up. \$\endgroup\$ Jul 16, 2016 at 7:11
