I'm currently working on a project that requires interfacing to a clock and data line at a configurable voltage between 0V-5V with nonstandard logic levels, this voltage is generated elsewhere. To be able to receive data the lines needs to be able to go into a high impedance state.
I'm currently playing around with a 4066, I have two lines of two pairs hooked together, one channel of the 4066 is hooked to the voltage and the other to ground and I simply drive them inverted. To get a high impedance state I drive both switches low. This being said it doesn't work real well since I'm having trouble hitting the ground rail.
All the buffers I found with tri-state outputs are for digital logic levels, could anyone recommend a analog one or another approach?
(For anyone interested I'm investigating the lowest voltages that I can use to interface to various IC's)
I eventually found this bug, I replaced the the 4066 with one from another manufacturer and it worked...
  • \$\begingroup\$ Perhaps you could accomplish something by paralleling the analog switch with an open drain buffer that would do a better job of driving to ground? \$\endgroup\$ Jan 5, 2012 at 18:59
    \$\begingroup\$ Also, it's not clear why you need to disconnect both the signal line and the ground (return) line. If you had a tristate digital buffer, it would only decouple the signal line. Do you really need to disconnect ground as well? \$\endgroup\$
    – The Photon
    Jan 5, 2012 at 19:34
    \$\begingroup\$ If Chris' supposition is right, the solution might be as simple as using a different switch. I couldn't get a selection table to show Ron on TI.com, but Analog has switches with Ron < 1 Ohm. \$\endgroup\$
    – The Photon
    Jan 5, 2012 at 21:29
    \$\begingroup\$ @s3c, There is a very common issue that I think may be occurring, often after troubleshooting an issue and attempting to resolve it when you ask a question about it a large amount is going to be based around what research you have accomplished. There is a large chance there is a fundamentally different approach to your issue that is used that resolves to an easily source low cost solution. If you can give us a bit more about what you the actual problem space is we may be able to understand. It sounds like you have a very low voltage digital signal you are attempting to recover. \$\endgroup\$
    – Kortuk
    Jan 6, 2012 at 3:52
    \$\begingroup\$ Which chip did you end up with? \$\endgroup\$ Jan 6, 2012 at 14:23
If I understand correctly, you are looking for an analog multiplexer with the option of setting the channels to high impedance.
If so, the 4052 or 4053 should do the job, they have an enable input which sets the ports to high impedance.
As mentioned in the comments, it might be a good idea to post a rough schematic of what you are doing, as it's a little unclear at present.
  • \$\begingroup\$ If I were in the same situation the most useful part to me would be knowing that the device I need is called an analog multiplexer. I have used them and knew that, but trying to find one looking for an analog tristate buffer I see as a daunting task. \$\endgroup\$
    – Kortuk
    Jan 6, 2012 at 3:50
  • \$\begingroup\$ The on resistance of these chips seems to be lower than the CD4066B but several times higher than the CD74HCT4066. Still, there are probably even better devices out there. \$\endgroup\$ Jan 6, 2012 at 4:33
Different `4066 devices have very different on-state resistances under various conditions. For example:
TI CD4066B is around 400 ohms at 0v input with 5v supply, but 100 ohms for the same input voltage if you increase the power supply to 15v. Cool it from room temperature to -55C and it's down to 70 ohms.
TI CD74HCT4066 is only 25 ohms for 0v input with 4.5v supply, at room temperature.
There are of course other manufacturers and other switch chips.
If you had a slightly negative power supply (-1V or so), you could use the FET switch with an op-amp follower circuit driving it and taking feedback from it's output, both powered from that negative rail and thus attempt to achieve unity gain from input to output of the assembly.
