I got a solenoid with the following data:
  • 1.25W
  • 24V
  • 460Ohm resistance
  • Inductance value unknown
I'm working on a sensor PCB which also needs to control the force of the solenoid. The sensor PCB is already using an ATTINY44 and has a 24V supply.
To control the force of the magnet I want to basically use a buck converter, with the ATTINY as controller. When configured as fast PWM 8bit with no prescaler and running on a 16Mhz crystal it should give a PWM signal of 62.5kHz.
This PWM signal I want to feed into the following circuit: enter image description here
The value of VOut5 is fed back by a resistor divider to one of the ATTINY analog inputs. The ATTINY ADC is configured to convert it in "free running mode" and the PWM signal is adjusted according to this value.
Which is basically working fine except for one Problem (btw. I want to control the magnet voltage VOut5 from 5V to 24V). To get the following voltages the PWM signal is settling at about:
  • 5V -> ~15% (PWM comparator OCR1B ~ 38)
  • 10V -> ~28%
  • 15V -> ~44%
  • 20V -> ~61%
  • 24V -> ~75% (PWM comparator OCR1B ~ 191)
This reduces my resolution to \$ Res=191-38=153\$ instead of 255. As I need quite a bit of precision I would like to use the full resolution of 255. By trial and error (mostly by changing the inductor value) I got to the chosen values in this circuit.
So my question: What do I have to change to get nearly the full resolution of 255 (e.g. 5V at close to 0% PWM and 24V close to 100% PWM)? Or is there a better way to than my trial and error (because each simulation run on my computer takes about 20min)? Can I calculate this?
As I need to make about 200 of these boards I would like to find a simple / cheap solution (that's basically, why I wanted to use the existing ATTINY, which had 2 free pins left as a controller in the first place).
P.S. to simulate this circuits behavior I build up below LTSpice model: enter image description here The part of the circuit in the red box emulates the ATTINY. Due to the rest of the program running on the ATTINY it is only able to adjust the PWM signal every 0.5ms (modeled by the sample and hold part. The LTC6992 is used to generate the PWM signal of 62kHz (R18 set to 800k) out of 0V to 1V voltage at the MOD pin. This emulates the behavior of the ATTINY pretty close.
The model can be downloaded here in case you need it.
  • \$\begingroup\$ Couple of things. Lload needs to have some resistance. For all practical applications, you can see it as a pure resistance. "Lbuck" - this is a design parameter. If you have too low inductance you will enter discontinuous conduction mode and you need to run at very low duty cycle. With your resolution problem, this will be a nightmare. Choose one large enough for deep continuous conduction mode and you can cheat with dirthering on your PWM duty cycle. \$\endgroup\$
    – winny
    Commented Jul 17, 2016 at 18:21
  • \$\begingroup\$ @winny: LLoad and LBuck have the series resistance parameter set to 460Ohm / 0.7Ohm - sorry should have mentioned that as you can not see it in the picture, but in the spice model I attached \$\endgroup\$ Commented Jul 17, 2016 at 23:29
  • \$\begingroup\$ Ok, that's better. How much inductance do you have in Lbuck? 2 mH. 50 mA and say 50 % of 62.5 kHz puts you at 96 mA delta - discontinuous conduction mode. Double it and you are at the edge of CCM. It's always hard to find inductors large enough when the current is too low and someone needs to wind it win an angels hair, or too high current for that matter. \$\endgroup\$
    – winny
    Commented Jul 18, 2016 at 7:47
(Most calculations that follow are not very precise, just close enough to guide some design decisions).
First off, M1 is driven too softly and therefore is not switching effectively. The driving impedance to M1 gate is around 10K, looking up the gate capacitance of 720pF, that gives a time constant of 10K x 720pF = 7.2us.
Comparing to the PWM period of 62.5KHz, that is 16us, the gate drive is way too slow and should be sped up by 2 orders of magnitude or so. That can be done by changing R2 to around 100 ohms (and R1 accordingly), but that has the undesirable effect of making the gate drive dissipation to be as much as the solenoid main load. The solenoid load current is no more than 24V / 460ohms = 52mA. So a smaller MOSFET M1 with much lower gate capacitance could be a better choice.
For an ideal buck: VOUT5 = V1 x PWM_duty_cycle .
So with V1 = 24V:
  • 100% -> 24V
  • 75% -> 18V
  • 50% -> 12V ...
This do not match your results. The very soft gate drive is a reasonable explanation, such that M1 is never quite turned off by the time the PWM drive signal gets to around 75%.
So by fixing the M1 switching, it gives you 100% -> 24V that you want automatically.
One simple way of getting 5V at 0% duty cycle is to connect anode of D1 to +5V. There is probably a +5V powering the ATtiny already. The average current requirement is around 5V / 460ohms = 11mA, and the peak around 52mA, which are not that much.
By the way, the main deviation of this circuit from an ideal buck is D1 with the effects showing up mostly when the duty cycle is low. The reasons are D1 has a voltage drop and also passes current only one way.
  • \$\begingroup\$ Connecting D1 to +5V is a good idea +1 \$\endgroup\$
    Commented Jul 17, 2016 at 20:16
  • \$\begingroup\$ Changing the soft driving of M1 actually already solved it! I change M1 to a BSS84P. Now 23.something V is close to 100% duty cycle! Perfect. 18V is at about 60%, 12 at 30% and 6 at 10%. Thanks for your help! \$\endgroup\$ Commented Jul 19, 2016 at 13:22
I have never faced this problem but it occurred to me that it is analogous to the problem of discrete grey-scale levels on bitmapped images. Continuous tones are generated by "dithering".
A quick search for "PWM dithering" threw up quite a few results. A dip into PWM resolution enhancement through dithering technique for STM32 advanced-configuration, general-purpose and lite timers (they don't go for pithy titles) gave the following information.
Figure 1. 1-added-resolution-bit PWM dithering.
The article goes on to discuss 1-bit and N-bit dithering which suggests that you could get multiple bit improvement on your 153 step resolution without changing your hardware. At 65 kHz you should be well below the mechanical reaction time of the solenoid.
I haven't looked around for code examples but how hard could it be? ;^)
  • \$\begingroup\$ +1 - rioraxe's answer solved the problem. But the dithering technique is an interesting idea! Maybe I will try it if I need finer steps! \$\endgroup\$ Commented Jul 19, 2016 at 13:26
