8
I'm looking at an application note, and it contains the following in the circuit diagram:
What does the NS in the diagram represent? Or is this just a typo on the behalf of the manufacturer?
Edit: Further down the datasheet, this is clarified as "Not stuffed"
What does that mean?
  • \$\begingroup\$ I would say it means something like "Not soldered" or similar. Meaning it is not populated in this assembly. \$\endgroup\$
    – Eugene Sh.
    Jul 18, 2016 at 18:33
  • 4
    \$\begingroup\$ Not Stuffed. It is in the data sheet in the BOM section. Not Stuffed means that it is not on the Board. \$\endgroup\$
    – Tyler
  • \$\begingroup\$ @Tyler: yep, you just beat me to it \$\endgroup\$
    – Eric
    Jul 18, 2016 at 18:42
NS means "No stuff". This is an assembly instruction. Nothing will be placed on the PCB for C7.
NS is yet another abbreviation along with DNL (do not load), DNP (do not populate), DNI (do not install), DNS (do not stuff), NOLOAD, OMIT.
Related threads
Why use "OMIT" components on a PCB?
'Not Mount' on PCB Design
Why does there seem to be a missing component in many PCBs?
  • \$\begingroup\$ "No solder" as well? \$\endgroup\$ Jul 31, 2016 at 11:53
