I have recently bought a L9110s H bridge (pictured below), and while testing I accidentally burned it up. I'd like to know why, to avoid making the same mistake and if maybe I should try to get a refund.
Datasheet: +=========+====================+=======+===========+=======+=========+ | Symbol | Parameters | | Range | | Units | +=========+====================+=======+===========+=======+=========+ | | | Min | Typical | Max | | +---------+--------------------+-------+-----------+-------+---------+ | VCC | Supply Voltage | 2.5 | 6 | 12 | V | +---------+--------------------+-------+-----------+-------+---------+ | Idd | Quiescent Current | - | 0 | 2 | uA | +---------+--------------------+-------+-----------+-------+---------+ | Iin | Operating current | 200 | 350 | 500 | uA | +---------+--------------------+-------+-----------+-------+---------+ | IC | Continuous | 750 | 800 | 850 | mA | +---------+--------------------+-------+-----------+-------+---------+ | IMax | Current peak | - | 1500 | 2000 | mA | +---------+--------------------+-------+-----------+-------+---------+
My setup:
- Motors: Generic motors from an old RC car. I can't see any number on them so I don't have much info. They came with a 100nF ceramic capacitor soldered on both ends. I have tried to connect them manually to the 5V and GND terminals of the power supply, and they worked just fine did not show any problems.
- Power: ATX PC Power Supply (5A/3A current), with VCC connected to the 5V entry.
- Situation: I connected the VCC and GND to a breadboard with 5V and GND from the power supply. When I connected A-IB to the 5V (to power a motor up), I heard a crackling noise, the two transistors started heating and emitting magic smoke, and they got so hot they actually fell from the chip. I screwed up real bad.
Schematic:
There are two things I'd like to know:
- What was my mistake and
- Was my L9110s bridge defectuous? I know it was probably my fault, but I think it's weird that the soldering was so weak the transistors fell out when it overheat.
