I found some 1-character 7-segment LED display in my toolbox with unusual pinouts. There is one however I can't seem to figure out and I even googled the part number with no results.
The part number printed on the side of it is "MAN4840A350G82", and my camera was good enough for me to show you pictures of how the pins are arranged on each side of the display. There are no other labels.
If I can't find the pinout on google, should I just assume some generic pinout?
I want to be able to use this display in a schematic created with eagle (yes I'm using version 4.17) but I don't want to pick the wrong LED display.
How do I identify what each pin represents on this display?
enter image description here enter image description here enter image description here
  • \$\begingroup\$ Look for similar chips using google image search. Find one, look at it's datasheet. the most important is to determine the GND connection. From there you can identify all of the pins by trial and error. \$\endgroup\$
    – Eugene Sh.
    Commented Jul 21, 2016 at 15:56
  • \$\begingroup\$ ... unless it's a common anode type @Eugene \$\endgroup\$
    – JimmyB
    Commented Jul 21, 2016 at 17:00
  • \$\begingroup\$ This one looks quite similar to your photos csee.umbc.edu/courses/undergraduate/CMSC391/summer04/burt/… \$\endgroup\$ Commented Jul 21, 2016 at 18:54
    \$\begingroup\$ -1 for the particularly crappy pictures. \$\endgroup\$ Commented Sep 19, 2016 at 16:20
    \$\begingroup\$ @OlinLathrop, now I think that's a little harsh. Satellite photography still has a ways to go in terms of resolution. \$\endgroup\$
    – user98663
    Commented Sep 19, 2016 at 16:25
5 Answers 5
A diode tester or a coin cell battery or a bigger battery with an appropriate resistor (1k or so). Map out every pin combination by hand. Since it's not a multiplexed display, it should be one cathode or anode to multiple of the other.
  • \$\begingroup\$ This is the fastest and easiest way to do it (even if you did have a data sheet). \$\endgroup\$
    – gbarry
    Commented Oct 19, 2016 at 19:01
Apply power through pairs of pins until a segment lights up. Now just move one probe at a time until another segment lights. The pin in common between the first segment and the second is the common anode or common cathode. You should be able to tell if it's the common anode or common cathode. Then simply test all the pins (with the appropriate probe on the common connection) until you know what segments are connected to what pins.
  • \$\begingroup\$ "apply power" is a bit imprecise - apply a current source or a high impedance supply such as a low voltage in series with a resistor. \$\endgroup\$ Commented Aug 20, 2016 at 17:01
  • They tend to be rather standard. Find something with the same number of pins in the same places on the same-size package and it's likely to be the same pinout, even if it's a different brand.
  • An appropriately limited low voltage test supply (5V, 300 Ohms, for example) and poking at pins.
Depending where it came from (ie, if it's a takeout) it could be partly dead or all-dead. Also not uncommon to have a pattern which includes features (decimal point or sign) that don't light up on some models in the line.
You can find the pinout here. I found this from the MANXXX part number, which is obsolete and a current cross-reference from Liton.
Though if it was not a standard part, probing with a 1K resistor in series with a 5V supply is fast and easy and will verify functionality.
Your camera is impressively bad- what the kids call a 'potato'.
I have a similar display as your picture. I use a digital volt meter to get the pinout.On the side with the 2 pins at each end, the middle pin is the GND. Hold the negative probe of the digital volt meter on that pin, use the red probe + to touch the other pins and you will see that each segment light up when you go from pin to pin. There is another GND pin on the side with 3 pins and 2 pins at the other end. The side that has the 3 pins the third pin counting from the end towards the middle is the other GND.
