In this example, transistor Q1 (a PNP one) has +12V in emitter and +15V in the base, the Vbe is +3, and being a PNP one, it is reverse biased with 3V. It is ok to bias like this ? I mean the transistor won't break ? How much reverse bias can withstand ? I have not seen this information in datasheet.
    \$\begingroup\$ See the transistor's datasheet ... there's usually a reverse breakdown voltage specification( Vebo) . 3V is probably OK for most transistors but 5V is pushing it. \$\endgroup\$ – Brian Drummond Jul 21 '16 at 22:34
13
The BE junction can be reverse biased, and your PNP will be off. The limit is the BE-junction breakdown voltage, as for any PN junction.
As long as you don't exceed that breakdown voltage, you'll be safe. The maximum reverse voltage the BE junction can withstand is usually listed in the datasheet in the Absolute Maximum Ratings section.
Here follows an excerpt from the datasheet of a jellybean PN2222 BJT (a "newer" version of the "famous" 2N2222):
PN2222 datasheet excerpt - absolute maximum ratings
And this is an excerpt from the datasheet of a PNP transistor of comparable (but complementary) characteristics (PN2907 - Fairchild):
PN2907 datasheet excerpt - absolute maximum ratings
Note, in general, that the limit is fairly low (5V..8V usually, even for power transistors), which is a strong hint that reversing the bias of the BE junction of a BJT is a risky business. So, unless you know exactly what you are doing, it is better to avoid reversing the bias of the BE junction for more than 1-2V.
In general 3V reverse bias is okay for most jellybean transistors- typically the rating is 5V or so, and the actual breakdown more like 9V.
This is not necessarily true for some RF transistors, which may have a much lower breakdown voltage.
There is, however a practical problem which may occur with your circuit. If the 15V supply comes up before, or stays up after, the 12V supply, the reverse bias will be 15V, and the emitter-base junction will break down for all but a few types of transistor.
What are the consequences of such breakdown? If the current is limited, as in your case to no more than 1.5mA, not much. The transistor gain may be permanently reduced if the current is large and sustained, or if the current is too large the transistor could even be destroyed swiftly.
