I have designed 3 power supplies with 3.3 V, 2.5 V, and 1.2 V outputs.
I use BD9870FPS Buck converter to step down 8 V - 24 V to 3.3 V.
Then the 3.3 V is used as inputs for 2 buck converters ENPIRION EN5322QI to step down to 2.5 V and 1.2 V. These 2 power supplies are used for load.
The 3.3 V output is also used for load.
The question is: when I tested three of them, the outputs (voltage) are stable, good. However, the current draw is decreasing while the input voltage to the 3.3 V buck converter is increased. Is this normal?
I read that a buck converter steps down voltage by increasing current. But what I got was another way around.
So, can you help me to explain this?
    \$\begingroup\$ Have you heard about the Conservation of energy law? You increase the voltage, so the current must decrease in order to maintain same energy consumption. \$\endgroup\$
    – Eugene Sh.
    Jul 22, 2016 at 14:52
  • \$\begingroup\$ What type of load is connected with output of the buck converter? If a constant power load then energy conservation. If not please explain the load nature. Is it a pure resistance or anything else? \$\endgroup\$ Jul 22, 2016 at 15:29
  • \$\begingroup\$ The load is an EtherCAT PHY and FPGA. What are their nature? Resistive I think. @SaprativSaha \$\endgroup\$
    – Ewo
    Jul 23, 2016 at 12:02
8
This means that the output current is higher than the input current.
What you are seeing is that the input current depends on the input voltage. This is true because of, as others have mentioned, conservation of energy. Because of conservation of energy, we can define the following rule for a buck (or other switching) converter:
$$V_{in}I_{in} = \frac{1}{\eta}V_{out}I_{out}$$.
Here, \$\eta\$ is an efficiency factor to account for power lost in the converter itself. It does vary slightly when the other parameters are changed, but it's typically between 0.85 and 0.95 for a well-designed buck converter.
So you can see that if the output voltage and current stay the same, but you increase \$V_{in}\$, \$I_{in}\$ will decrease.
  • \$\begingroup\$ Yes that's what I thought. But when my teacher asked me about this, he told me that the current should be increasing when the input voltage is increasing. That's why I'm confused. I think he is wrong after all. \$\endgroup\$
    – Ewo
    Jul 23, 2016 at 11:32
  • \$\begingroup\$ Your teacher is either wrong or didn't understand your question. A switching converter with a fixed load is a negative-resistance load for the source that supplies it. \$\endgroup\$
    – The Photon
    Jul 23, 2016 at 15:39
  • \$\begingroup\$ So I have also this AC to DC power supply (transformerless capacitive power supply). When the input voltage is increased incrementally from 180 V to 230 V, the current draw is also increased. How about this? \$\endgroup\$
    – Ewo
    Jul 24, 2016 at 5:16
8
Yes! P=U*I. Increase voltage and the current drops and vice versa. It's the entire point of having a switcher instead of linear supply.
Your logic is incorrect.
1) You step down the voltage by increasing the current.
2) Therefore, the more you step down the voltage, the more you can increase the current.
3) The more you can increase the current, the less input current you need for the same output current.
4) Therefore, the more you can step down the voltage, the less current you need.
5) Thus the higher the input voltage, the lower the input current.
