The last time I did a successful PCB, the drill hole size relative to the component pad size is rather huge to the point where when I entered the soldering stage, the component wires were not connecting to the pads correctly.
What I want to do in eagle is change the drill holes on every device (with small pins) on my PCB so that they are about 1/64ths of an inch instead of Eagle's preferred size, that way, when I drill, I drill a small amount of copper but at the same time, the copper will meet with the hole and the odds of a strong connection are higher.
Is there a quick way I can make the drill holes smaller in eagle without having to manually edit each part one-by-one?
