I am attempting to identify brass casings vs aluminum casings. I'm been trying to figure a reliable way to differentiate between the two. I've thought about
- Color: This may work, but I fear that dirty optics and targets may not work so well.
- Weight: I'm not really sure how to implement this in my context.
- Conductivity/Resistivity: Perhaps an inductive sensor? But aluminum is very close to the same value as brass.
- Ultrasonic properties: This may not work with varying levels of dirt. But I really don't know much about it.
I prefer non-contact, and a solution that is impervious to contamination, but I'll take any suggestions given.
It seems that an inductive sensor would be the way to go. I'm okay with rolling my own, perhaps a couple of tuned coils which the target passes through?
Okay, thanks to Charles for getting me on the right track. It looks like I'm needing an eddy current sensor.
These are shell casings, and when run through the machine will all be of the same caliber, so the uniformity should be good. For material identification, distance from the coil is important, and since the target is not always in the same position, I'll run the casings through the coil center, which should be immune from position errors.
It looks like some aluminum alloys overlap the brass alloys in resistivity, but I bet that the alloys used in cartridges are very consistent. I do have another bit of information, and that is the actual identification of the head stamp. Headstamp coupled with resistivity should get me a very accurate indication of what type of metal the cartridge is made from.
