PIC18F2550 and DS1307 i2c RTC MPLAB assembly code.
I am using a PIC18f2550 to get time,date,etc from DS1307.
  • I am able to get the seconds,minutes, hours, etc by repeatly CALLing GET_TIME with a new Read Address 0 to 6.
  • I am unable to get all the Parameters sec, min, hrs, etc in one reading as below in Read_Clk.
Could someone tell me what I am doing wrong? Using it as it is only returns "Seconds" in each of the seconds, minutes, hours, etc.... I have posted a picture because of lines offset.
WAIT_PIR_SSPIF:
    BTFSS   PIR1,SSPIF
    GOTO    WAIT_PIR_SSPIF
    RETURN
WRITE_CLK:    ;Write data to slave.; //Write data to I2C bus
    BCF     PIR1,SSPIF
    MOVFF   WRITE_DATA,SSPBUF
CheckWrite:
    BTFSS   PIR1,SSPIF
    GOTO    CheckWrite
    RETURN
GET_TIME:
    CALL     START_CLK
    MOVLW    b'11010000'
    MOVWF    WRITE_DATA
    CALL     WRITE_CLK
    MOVLW    b'00000000'           ;ADDRESS OF TIME TO READ
    MOVWF    WRITE_DATA
    CALL     WRITE_CLK
    CALL     DELAY_2nd
    CALL     RESTART_CLK
    MOVLW    b'11010001'
    MOVWF    WRITE_DATA
    CALL     WRITE_CLK
    BSF      SSPCON2,ACKDT         ;SAME AS "NACK"
    CALL     DELAY_2nd
    CALL     Read_Clk                       ;CALLS READ_CLK
    CALL     STOP_CLK
    CALL     DELAY_2nd
    GOTO     GET_TIME
Read_Clk:             ; //Read data from I2C bus
    BSF     SSPCON2,RCEN
    BCF     PIR1,SSPIF
    CALL    WAIT_PIR_SSPIF
    MOVFF   SSPBUF,SECONDS
    BSF     SSPCON2,ACKEN
    BCF     PIR1,SSPIF
    CALL    WAIT_PIR_SSPIF
    MOVFF   SSPBUF,MINUTES
    BSF     SSPCON2,ACKEN
    BCF     PIR1,SSPIF
    CALL    WAIT_PIR_SSPIF
    MOVFF   SSPBUF,HOURS
    BSF     SSPCON2,ACKEN
    BCF     PIR1,SSPIF
    CALL    WAIT_PIR_SSPIF
    MOVFF   SSPBUF,DAYS
    BSF     SSPCON2,ACKEN
    BCF     PIR1,SSPIF
    CALL    WAIT_PIR_SSPIF
    RETURN
DELAY_2nd:
    MOVLW   b'00000100'
    MOVWF   COUNT_DOWN
DELAY_2:
After spending many hours on the internet I have come up with an answer to my own question. Below is the Updated code that in some parts replace the above code. PIC18F2550 and DS1307 i2c RTC MPLAB assembly code. Code used to get time,date,etc from DS1307.
Ds1307 Pic18f2550 assembly code for Time
  • \$\begingroup\$ Ugh. Pictures aren't searchable. OP, please remove the picture and post the answer as a code block. \$\endgroup\$ – Adam Lawrence Aug 30 '16 at 0:07
